20 Most Recent Lorex L23WD845 4-Camera Security System with 23" LCD Monitor Questions & Answers
Lorex WL2700 blue screen and shaking
plug the camera directly to monitor if no change check connectors and cable
4/25/2016 10:28:25 AM • Lorex L23WD845... • Answered on Apr 25, 2016
2answers
I unplugged my L23WD system while trying to expand
U over loaded the system right there,4 to 8 tries 4 again might work again,if have u not burn out the expanded ports already.
1/24/2015 11:27:31 AM • Lorex L23WD845... • Answered on Jan 24, 2015
My lorax security system is 4 cameras and one is not working only blue screen shows on monitor
CHECK POWER SUPPLY TO THAT CAMMERA THAT GIVES BLUE SCREEN
12/5/2014 1:42:02 AM • Lorex L23WD845... • Answered on Dec 05, 2014
0answers
Lorex
Be the first to answer 6/20/2013 3:16:21 AM • Lorex L23WD845... • Posted on Jun 20, 2013Be the first to answer
0answers
I accidently unplugged my system
you need to upgrade the firmware of your lorex survillance camera.
4/1/2013 5:25:06 PM • Lorex L23WD845... • Answered on Apr 01, 2013
L23Wd800 Monitor blinking cameras blue
Take it easy, change the tuner or the video chroma jungle.or check your connection, like some dual lens video recorder.it can solve it
11/7/2012 6:33:05 AM • Lorex L23WD845... • Answered on Nov 07, 2012
My lorex L23WD800 monitor have no signal and the viewed blue color all channels
check the tuner or the video chroma jungle(VCJ)
5/9/2012 1:47:04 AM • Lorex L23WD845... • Answered on May 09, 2012
0answers
2answers
Bought an UPS power supply
edward_sm123,
From your description it certainly sounds like the problem is with the security power supply. If the power did drop (brown out) or bump (spike) it certainly would explain the security unit failing. With a UPS on the system though I would not have expected the power to change. You may also have a problem with the UPS which could be causing the problem with your security system. Unfortunately the only way to find out if you have a problem with the UPS is to monitor the output with a recording voltmeter. If you have one I would hook it up to the UPS and monitor the unit for about a week with equipment hooked to the UPS to load it down. If it can survive a week without failing it should be OK. If it doesn't replace it. As far as the security system if it is under warranty I would go to the manufacturer for another unit. If it isn't under warranty I would troubleshoot the power supply, replace the power supply board or take the unit to a shop which can repair it. Usually the schematics can be found for free on line. This will make it easier to troubleshoot. I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which explains how to troubleshoot a Television Low voltage and high voltage circuits which may help you.
Thanks for using FixYa and for the great rating.
hardrocko
5/12/2011 2:28:02 AM • Lorex L23WD845... • Answered on May 12, 2011
Can my Lorax mc2700 be viewed from my phone
The Lorax MC2700 is a portable radio that does not have Wi-Fi or Bluetooth connectivity. As a result, it cannot be viewed or controlled from a phone or other device. It can only be controlled using its physical controls
3/13/2023 6:17:47 PM • Lorex Home... • Answered on Mar 13, 2023
My lorex DVR won't turn on
If your Lorex DVR won't turn on, it is likely that the power cord is not properly connected. Make sure that the power cord is securely connected to the DVR and that the power switch is in the "on" position. If the problem persists, you may need to replace the power cord or contact the manufacturer for assistance.
1/29/2023 7:23:55 AM • Lorex Home... • Answered on Jan 29, 2023
How can i get temporary password for lorex LHV221600?
Not from us! We are Fixya dot com, we aren't Lorex. Here is a link to their Support. https://help.lorextechnology.com/ ..
4/27/2022 1:56:38 AM • Lorex Home... • Answered on Apr 27, 2022
I need lorex bios dump lh0414-d
Lorex Firmware Updates ' Lorex
www.lorextechnology.com > support > Firmware
download the lastest firmware for you lorex products such as dvr, nvr and security cameras, you will be able to upgrade your system upgrading your firmware.
12/31/2020 12:29:47 AM • Lorex Home... • Answered on Dec 31, 2020
Lorex L23WD845 4-Camera Security System with 23" LCD Monitor Logo
Popular Tags
20 questions posted
Top Lorex Home Security Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
View Most Popular
Lorex Home Security
  • Lorex Home Security
Most Popular Question
l23wd800 monitor blinking cameras blue
  • Home Security
