20 Most Recent Proscan PS35660 TV Questions & Answers
2answers
Lost the manual. Can't re-program remote control. Need step-by-step
http://www.rca.com/documents/15128800_201059_25.pdf Hope this helps :)
11/26/2012 12:24:57 PM • Proscan PS35660... • Answered on Nov 26, 2012
2answers
Audio not working on proscan ps61700
I have a GE 46 in TV that had the same occurrence. I believe it is a sign that the amplifier is overheated or stressed. The way I fixed mine was to unplug TV and leave off for a few minutes -then plug in. I discovered this by accident when the power went off one day and the sound returned (had been using my vcr audio output plugged into my stereo for weeks!) This fix will work for weeks-sometimes months-evidently resets the circuits inside the amp somehow. Last time this happened I also removed the back of TV and blew out the dust with compressed air while it was unplugged-still have sound 4 months later without a "reset"-so I'm guessing it did help .
8/19/2010 8:35:56 PM • Proscan PS35660... • Answered on Aug 19, 2010
Guidec plus wont get listing any more
If it wont work since the change over to digital,
it cannot search because of the signal difference.
7/4/2009 4:12:59 AM • Proscan PS35660... • Answered on Jul 04, 2009
2answers
My Guide Plus does not work
Mine stopped mid-
December. I used the old reliable 99999 as my zip code, turned off the tv for an hour, turned it back on, entered my correct zip code and was patient. Today, the 15th of January, it popped back up. I have a feeling that it is all due to the switch over. I think different cable companies are setting things up and the gude was lost during that time. Maybe if you are patient, it will pop back up also.
5/18/2009 7:23:24 PM • Proscan PS35660... • Answered on May 18, 2009
When i turn it on it goes fft fft fft then shut off
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer..
4/17/2009 1:07:46 PM • Proscan PS35660... • Answered on Apr 17, 2009
Wont turn on green light comes on then shuts right off
Wii is compatible with all projection TV, try lowering down resolution settings on Nintendo and check PAL/NTFS settings.
4/17/2009 1:07:30 PM • Proscan PS35660... • Answered on Apr 17, 2009
Proscan TV powerup
4/17/2009 1:06:04 PM • Proscan PS35660... • Answered on Apr 17, 2009
2answers
Proscan tv 36in
Many problems with this unit with the HV transformer (flyback) and also a regulator ic in the power supply. Sorry, nothing easy for this type of problem. You will need a tech to diag. and repair this problem.
4/1/2009 1:17:32 AM • Proscan PS35660... • Answered on Apr 01, 2009
Pro Scan doesn't power up
Pro Scan/RCA TV's (Pro Scan's are just glorified RCA's TV's) don't hold up very well (cheap components). You can try removing the back and checking the fuse/fuses (could be that simple), but if it's over 5 years old? You may be looking for a new TV soon.
You should find a fuse on the circuit board near where the power cord goes into the back.
I hope this helps, and Good Luck.
2/25/2009 8:52:06 PM • Proscan PS35660... • Answered on Feb 25, 2009
0answers
Model PS36605
Be the first to answer 12/23/2008 12:08:51 AM • Proscan PS35660... • Posted on Dec 23, 2008Be the first to answer
3answers
Proscan ps35653 will not turn on after recent move
yes it could be the problem of power supply.
9/1/2008 12:48:31 AM • Proscan PS35660... • Answered on Sep 01, 2008
26LA30Q32LA30Q
If it is a glass screen there is nothing you can do to it. First the tube is not available and second too costly if it was. Third the only chance is a used tube from a junked out tv at a repair shop and that will cost too but not as much. But seeing that it is a CTC 179 and assuming the long number is the serial number, it will be hard to find. If that is not the serial number then I'm sorry for I am completely wrong! If it is a lcd tv then the screen cost usually about three quarters the price of the set. Sorry about your problem. Hope this helps At this point I am assuming from deductions that it is a LCD.
12/31/2007 5:21:50 AM • Proscan PS35660... • Answered on Dec 31, 2007
My proscan elite peltdv1029 combo. I locked it by accident and have no password help!
It is a standard Android Hard Reset. You will get an option to backup your data. https://www.google.com/search?q=proscan+elite+peltdv1029+factory+reset
3/8/2023 1:49:38 AM • Proscan... • Answered on Mar 08, 2023
Does a proscan model PLED5544U have a reset button
The Proscan PLED5544U is a 55-inch LED TV. While it doesn't have a physical reset button, there are a few ways you can reset it:
  1. Unplug the TV: Unplugging the TV from the power outlet for a few minutes can help reset it. This allows any residual power to dissipate and can clear any minor software glitches.
  2. Use the remote control: Press and hold the power button on the remote control for at least 10 seconds. This can sometimes reset the TV.
  3. Use the menu: If you can access the TV's menu, you can try resetting it through the settings. Go to the "Settings" menu, then "System" or "General" settings. Look for an option to reset the TV to its factory settings.
If none of these steps work or if you're experiencing other issues with your TV, it may be best to contact the manufacturer or a qualified technician for assistance.
2/27/2023 6:07:50 PM • Proscan... • Answered on Feb 27, 2023
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
2/26/2023 4:02:08 AM • Proscan... • Answered on Feb 26, 2023
I have a proscan elite tablet and dvd combo. Some how I locked it. Help!
If your Proscan tablet and DVD combo is locked, you can try the following steps to unlock it:
  1. Restart the device: This is the simplest and quickest solution. Simply restart the device by holding down the power button until it shuts off, then turn it back on.
  2. Check the lock button: Some devices have a lock button that can be used to lock and unlock the device. If your Proscan tablet has a lock button, check to see if it's in the locked position and adjust it if necessary.
  3. Reset the device to factory settings: If restarting the device and checking the lock button don't work, you can try resetting the device to its factory settings. This will erase all data and settings on the device and restore it to its original state. To reset the device, you may need to access the settings menu and look for an option to reset the device or perform a factory reset.
  4. Contact the manufacturer: If you're unable to unlock the device using the steps above, you may need to contact the manufacturer for further assistance. They should be able to provide you with more specific instructions on how to unlock your device, or if necessary, repair or replace it.
I hope this helps! Let me know if you need anything else.
2/12/2023 6:26:49 PM • Proscan... • Answered on Feb 12, 2023
2answers
Proscan 3373A. Hard reset for 3373a Proscan
The model doesn't exist. All question need 'make model (what it is)', first 3 words and in that order. "channel button". is it a television? Reset would be in Settings / General. You have the Remote? All sets need a Remote. https://www.google.com/search?q=proscan+3373a They make a lot of stuff! Proscan Video - TVs, tablets, DVDs, and camerashttps://www.proscanvideo.comProscan manufactures and distributes quality electronics & appliances such as Televisions, Tablets, DVD systems, portable and home stereos, and cameras.‎Contact Us · ‎Television · ‎About Us · ‎Manuals & Downloads Proscan Tablet reset, Standard Android Hard Reset.
1/29/2023 6:26:15 PM • Proscan... • Answered on Jan 29, 2023
How do i turn down a proscan tv without remote there's only a power button on the i tried everything ...And ideas
No MODEL details and one of my favourite manual sites says they have 400 Proscan manuals. They ALL have basic controls for On/Off, Volume UP and Down and Channel Up and down. Get behind and at the sides the television and your will see them. This model has them on the right edge. https://www.manualslib.com/manual/484183/Proscan-42lb45q.html?page=9#manual also read this. You need a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/8/2022 5:22:19 PM • Proscan... • Answered on Dec 08, 2022
Have a plcd3992a proscan tv. It cuts on says proscan then disappears. What to do ?
I'd recycle the set and buy a better brand like LG, Samsung ect. Proscan TVs are plagued with problems and in most cases not worth repair
11/10/2022 10:29:12 PM • Proscan... • Answered on Nov 10, 2022
Televison & Video Logo
19 questions posted
Top Proscan Televison & Video Experts
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
proscan tv powerup
  • Televison & Video
