If the RED and GREEN lights are not on this indicates power is not getting to both sensors. There should be around 11vdc at the two wires going into the master sensor (red light). Yours might be different. If it's not there, test the voltage at the controller. Mine reads 11.4vdc but your voltage may be different for your model; mine is a 1S550/A.If the voltage is there disconnect the 2 wires from the controller (make sure you have the pair going to the sensor) and twist them together. Then go to the Master sensor (red light) and read the resistance across these same wires...should be around 0 ohms. If not there is an open in one of these wires. 2conductor telephone wire is a good replacement. Watch your polarities.The factory red + white is normally positive, the all white is negative.The slave sensor (green light) is connected in parallel with the master sensor.
Check on the control box - there will be turn switch to adjust the load sensor. Turn it slightly to any direction and try the door. If the problem worsen turn it in the opposite direction until the door function correctly. Remember load sensing is a safety mechanism to sense when something is in the way of an opening or closing door and will stop movement before injury or damage occur. It is however sometimes set to sensitive resulting in the door stopping for no apparent reason. It should be set to such a level that the door will stop when held back by hand.
Question edited for clarity.
Question moved from Cars and Trucks category.
Look at the corners of the doors that hold the aluminium frame together and if it is a modular door, tighten them up. If it is a solid door, adjustment can be made by shimming behind the bottom hinge with a piece of cardboard. This will move the bottom out and up.
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button.
http://www.youtube.com/watch?v=7CqMy2UfG9k
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube.
If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
At NHK Tiling, our tiling process has been perfected over the years to give you the best results possible. Our Expert Tiling Service is perfected for a range of applications, styles and functions. Whether you require contrasting grout to make a statement with your kitchen splashback, or you need a Professional Tiler for tiling your swimming pool, NHK Tiling is the ideal choice for you.
https://www.nhktiling.com.au/
GRANITE WAREHOUSE is a privately owned Western Australia business specializing in the wholesale of Granite, Marble, Limestone, Sandstone and our line of engineered stone, Stellastone, in slab form suited for the fabrication of kitchen and vanity benchtops as well as other building uses.
Granite Warehouse was founded in 1995 by Tindaro (Tony) Tomeo to fill a need in the local Western Australian market for quality natural stone. With more than 40 years experience in the building industry, specializing in cabinet making and kitchen fit-out, Tony, with wife Susan and son Mark, built Granite Warehouse into the well-respected business it is today.
With Tony and Susan's retirement, and in the best family tradition, Granite Warehouse has been taken over by Mark Tomeo who continues to develop the business to fill best the needs of those wanting to enjoy the beauty of stone installed to their home or business.
https://granitewarehouse.com.au/
Having operated for the past 11 years in Western Australia, we offer a wide range of quality construction and demolition related services at competitive rates.
Operating with the latest equipment endorsed by Traxx Construction Products, our fully qualified and professional operators work to the highest safety standards with excellent service guaranteed to meet your every need.
Our team of qualified professionals, well trained and certified personnel who can operate the latest high-tech machines implement every project with care and 100% attention to details. To make sure that we are always ready for action and up-to-date with technologies, fast-paced world, procedures & regulations, we keep proving educational and on the job training to every professional we have in our team.
Kwikcut believes in the importance of collaborating ideas and exploring innovative concepts not just for the benefit of our company but above all for the benefit of all our clients. We are customer focused, and we all share the same vision which is to put attention to details and produce nothing but excellent results for every project laid before us.
We are highly professionals, trained, skilled, and licensed. For us, no job is too small or too big that we cannot undertake.
https://www.kwikcut.net.au/
Evolution Epoxy Flooring is Sydney's epoxy flooring expert, specialising in decorative garage coatings & concrete grinding. We only use advanced techniques, custom design, and Australian-made products to ensure the best concrete finish that suits the individual client's needs.
https://evolutionepoxy.com.au/
earth-friendly products is good for us this means it's products that was made from things that could be reuse and made better for our health and environment will be better
