20 Most Recent
HEWLETT-PACKARD Hewlett Packard 348349-001 - HP TC1000 & TC1100 10.4 XGA 1024x768 Laptop Touchscreen LCD Module Kit (Complete) Tablet PC Questions & Answers
TC 1100 UNSUPPORTTED WIRELESS DEVICE
More information needed. Not sure if I can help you but others may be able to if more information. Is the device a
if it is it should have a 802.11 wireless controller built into it and a rj45 ethernet connection.
Please explain what is on the other end do you have a wireless router to connect to ? Does this work with other devices or is this a new setup. Do you have a user manual does it have 802.11 built into it. Using other cards how are you using other cards are they usb devices plugged into the usb interface. They would need the correct driver installed and if the tablet has a wireless adapter built in they would conflict with each other . The windows xp running on the tablet would most likely be a special version that runs on tablets if it is a tablet.
HP tc1100 power issue
Go to ebay and search for "tc1000 charger". You'll be able to find one for 10 at the most with free shipping most the time.
Why can't i see captured pictures on my touchpad?
1, First, open the Settings option and select Device Information.
2, Choose the More information button and then select Software on the top of the next screen.
3, Scroll down and select Photos and Videos. A pop-up window appears and select Done.
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
The android process in my smart eurostar tv. screen has stopped - how can i fix this problem
eurostar tv problem fix boot issue remove tv from power outlet hold down the power button and volume less button (negetive button) to boot make it boot in usb or auto reset from default software if it does not work then you need to download the correct motherboard firmware or software and format the usb fat32 and copy into it firmware files are avalable below my button did not work so removed firmware you need a telegram account can be downloaded from the link below https://gofile.io/d/M98jbz ( if this link not working then download from telegram account this is for eurostar 32 inch tv ) original link from telegram here https://dipelectronicslab.com/eurostar-t32sled-a14-update-software/ other webiste wheich helped me https://www.kazmielecom.com/ Try the key combination if inverted screen and colour https://www.youtube.com/watch?v=pZsGDgD6JQQ if the service mode does not come then use the command when the input selection menu is open and using the remote the following command menu 1147 menu 8896 menu 2580 source and 2580 source and 308(this worked for me it worked when i was after reset i selected inside tv then i open source menu in cvbs1) source and 208 search youtube if you are still not able to open there are videos where people show menu and number in source option 1) in the service menu if your screen a)if inverted screen issue go to panel settings LVDS mirror mode if on then off it (if off then on it) b)if clour is inverted LVDS map change it to next option (if vesa change to jeda) there is any other issue this both website hav tutorial for any other isssue
1/18/2024 5:25:00 PM •
Tablets &...
Answered
on Jan 18, 2024
How do I connect my PIXMA ip2820 to print from my google tablet
Methods that Setup Canon Pixma Ip2820 Printer Easily:-
1. Keep your Canon Pixma iP2820 printer on a place where you can handle it easily.
2. Insert the cartridges into the preferred slots.
3. Connect the power cable of the printer to complete the printer setup process.
If the Set-up does not work To
Setup Canon Pixma Ip2820 Printer, you want to join with Printer Error Support experts. You can also follow the easy steps to Setup Canon Pixma Ip2820 Printer are given below in the BLOG link.
12/18/2023 2:57:59 PM •
Tablets &...
Answered
on Dec 18, 2023
