20 Most Recent
Rocketfish RF-1025VA UPS System Questions & Answers
I have a rocketfish 1025
Well, first let address the lack of power usage from your router and cable modem. The router, depending on model, may only use less than 5 amps of of power, depending on the load it is using at any one time, the cable modem is using maybe 2 amps, at peak load, since the line is already powered from the cable company, there is no real load. Since the usage is much less than 1 watt, it would not register on your meter. The reason why unplugging your devices from the wall, for it to not provide backup power to all of the devices is the battery(ies) may not be providing enough juice to maintain the power required for ll of the devices plugged in. Also, UPS are generally not compatible with power strips and therefore do not tend to function properly with a devices powered on the strip. They generally won't complete the power connection due to the strip carrying a much higher load than the UPS can support. This should explain all of your power issues. If you require additional information, please do not hesitate to ask.
Rocketfish...
Answered
on Aug 19, 2011
My mouse will not work
Check to see if any thing works on it at all, and if not go to Device Manager and see if there is a conflick with it.you can try looking for updated drivers for as well.
Rocketfish...
Answered
on Sep 02, 2010
I don’t know what is F4 how to solve this
F4 is one of what is called function keys. They are keys above the row of number keys which are above the alphabetic keys on the keyboard. The result from pressing a function keys varies by brand of computer. With some computers, you must press a key called the FN key as well as the numbered F4 key in order for what ever that key is programmed to do to proceed. Even more confusing it that you can press the FN key simultaneously with just a sheer number in order to perform other tasks. But there is indeed a key just labeled the F4 key, even if in some cases you must press a FN key as well as it. You need to search for a list of what your function keys do for your brand of computer. For instance "function keys for HP laptops" or "function keys for Toshiba laptops." When you post questions, it is helpful for you to list brand and model of your device.
Computers &...
Answered
6 hours ago
Up date for my now bible audio
Page 57 of your user manual say you can register your product in order to receive emails about any software updates to the product. It also goes some way to discuss how to update the software if there is such an update available. From about page 52 onward discusses matters such as connecting your device to the computer's USB port.
The product appears to have multiple functions for recording notes and playing MP3 files. Additionally, it is mentioned that cards may be added to it. The device has a menu item called TOOLS which has a submenu item regarding software updates. It short, you have to download any software updates to your computer and install them to the NowBible device through the USB port in conjuntion with the menu item for software updates. Take a look at page 57 which online is page 62..
https://www.manualslib.com/manual/745230/Danteck-Nowbible-Color.html?page=62#manual
Computers &...
Answered
6 hours ago
How do I delete items from the history
You can delete history from Google Chrome very easily. Just follow these steps.
1) First click on an icon displayed in following image. you can find this icon below close button on google chrome. then go to History & then click on History.
2) Now you will see all your browsing history. At bottom of history you will see the Clear browsing data button. Just click on that.
3) After clicking you will the following window will open, here just click on displayed Clear browsing data button at below of window.
Now you have successfully cleared browsing history of google chrome.
Computers &...
Answered
15 hours ago
Black borders on either side of creen
Is it a laptop or desktop?
If laptop, check it's not in 4:3 mode Usually pressing the FN and one of the "F-keys" does it. The key will have an image that shows the borders like on your screen.
If it's a desktop, check in your display settings. have you got the resolution set correctly?
Computers &...
Answered
19 hours ago
PC no longer boots after update: Error 0xc0000428?
To Troubleshoot no boot situation, follow the below steps:
Method: Create a bootable media and perform start up repair.
Step 1: I suggest you to try creating a new bootable USB and once the bootable media is created.
Step 2: Follow the steps mentioned below to perform Start up Repair:
1. Insert the installation DVD or USB and boot Windows 10 from it.
2. Select "Troubleshooting" from the first Window and then select "Advance Options".
3. Then select "Automatic Repair" from "Advanced options" window.
If that method doesn't serve you well, you could refer to this article:
[Solved] Blue Screen of ***** 0xc0000428 Error
Computers &...
Answered
Yesterday
Is it possible to zoom
it cant be saved when zoomed in but you can buy software that will allow you to increase the size and save it ask you local computer retail shop for advice on the program to install photo smart is a good one
Computers &...
Answered
Yesterday
How do I log into my Rackspace Email?
We all know that Rackspace is a cloud company that makes it easy to manage private and public cloud deployments. It is the largest managed cloud service provider and offers its services or expertise to various cloud platforms such as Amazon Web Services, Azure, and more.
Getting access to the Rackspace account is pretty simple, just follow the steps we've listed here.
How to login to Rackspace Email
If you want to access
Rackspace login webmail, then you should follow these steps.
- First, you need to open a web browser on your computer and then enter apps.rackspace login URL in the bar and hit enter.
- Now, you will see a webmail login page for all your Rackspace apps.
- Here, you need to enter the email address in the first text box located on the page.
- And then, provide the password for the account in the second box located right below it.
- And lastly, click on the login button to proceed and if the username and password combination is correct, you will be able to login into your account.
So, this is how you can log in to your Rackspace email account with ease.
Computers &...
Answered
Yesterday
