20 Most Recent Western Digital Caviar SE 250GB 7200rpm EIDE 100MB/s 8MB Internal) ATA-100 Hard Drive Questions & Answers
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Western Digital... | Answered on Aug 13, 2012
Hard drive can make a nice paper weight. It's toast.
Western Digital... | Answered on Aug 16, 2017
No diagrams or parts. WD may be able to repair it for you.
In some cases an IDE connector is added to RAID Hard Drives or Industrial grade desktop computer drivers.. it's a backwards compatibility measure in case of failure.
Other driver may also include an IDE power source too..
Those IDE connections are also known as (PATA) or Parallel.
Western Digital... | Answered on Nov 21, 2014
WARNING Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Test all leads that attach to your hard drive power and data cables IDE ,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
Make sure all leads that are attached to your dvd \ cd floppy drives have secure connections and are not faulty or just replace them they could be faulty.
Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error.
Even something as small as a faulty electrical or fan lead can cause you problems
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
Western Digital... | Answered on Jul 30, 2013
..as i know when HDD start beeping ( internal or portable ) that indicate problem with the Hard Drive (HDD)..so nothing you can do it by your self ..
..if the HDD is under warranty from factory you may take it to the store that you buy or nearest Western Digital distributor to claim the warranty...but if it doesn't in warranty..that's mean a problem why?
because if HDD start beeping like you have, the possibility to make it work again is almost impossible that mean you maybe lost the data that you save in this HDD..
Western Digital... | Answered on Sep 03, 2012
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Western Digital... | Answered on Aug 04, 2012
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
hope this helps
Western Digital... | Answered on Jul 13, 2012
Please give us some more information on exactly whats happening. Are you trying to connect this to a desktop PC or put it in an external exclosure?
For a desktop PC, the basic steps to try are:
1 - Ensure both the IDE cable and molex cable are connected to the hard drive. If it still doesnt work...
2 - Test the drive with a different molex connector that is known to work. Only connect the molex connector (4 pin power connector) and not the IDE data cable.
If the drive still doesnt spin up, it would appear the drive is faulty and requires replacement.
For an external enclosure:
1 - Take the enclosure apart and take the drive out. Test it in a desktop machine by using the above steps. This will let you know if the drive or the enclosure is at fault.
Hope that helps!
Western Digital... | Answered on Jul 03, 2012
You need to run chkdsk......
How to run Chkdsk
Notes
Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer
Double-click My Computer, and then right-click the hard disk that you want to check.
Click Properties, and then click Tools.
Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
To run Chkdsk in read-only mode, click Start.
To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Exit code Description
0 No errors were found.
1 Errors were found and fixed.
2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified.
3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
Western Digital... | Answered on Jul 01, 2012
How to run Chkdsk
Notes
SATA stands for Serial ATA and describes the interface used to connect to your PC. Many older PCs have ATA or UDMA, an IDE type interface. Many newer PCs have a SATA interface. You can buy and add a SATA interface card if no additional SATA ports are available on your system. SATA drives have a small data connector and a larger power connector. Each drive has it's own SATA data cable, no daisey-chaining like IDE drives did. Since there is no daisey-chain there are no jumpers that need setting for Master and Slave.
Western Digital... | Answered on Feb 27, 2012
You should not even try to install an operating system on an external drive. Windows looks at the "C" drive and installs programs to "C" drive. You are trying to put it on the "G" drive. You will have too many problems and wish you never had tried. Buy a larger main drive and partition it with two equal partitions. Then "Dual Boot". You will find how to do this on the internet. Just Google "Dual Booting".
Western Digital... | Answered on Sep 09, 2018
Get TESTDISK and see if it is recognised, if so TestDisk has some tools that may help
Western Digital... | Answered on Feb 06, 2018
hirens boot disc can sometimes crack 32bit passwords
http://www.hirensbootcd.org/
here is a link with some instructions
http://forum.hddguru.com/viewtopic.php?t=19569&start=
Western Digital... | Answered on Jan 19, 2018
Western Digital Caviar SE 250GB 7200rpm EIDE 100MB/s 8MB Internal) ATA-100 Hard Drive Logo
1 questions posted
Top Western Digital Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Caviar Western Digital
  • Caviar Western Digital
Most Popular Question
new western digital desktop pata eide
  • Computers & Internet
