20 Most Recent
Polaroid Portable DVD Player PDM-0822BD Questions & Answers
My Polaroid DVD player - Model # PDM0822BD player
If the disc does not rotate it means there is something wrong with the power supplying the disc motor or the motor itself is defective. Try to rotate the disc motor manually, If its rotating freely then the problem is in the circuit that supplies the disc motor.
5/25/2020 1:50:05 AM •
Polaroid...
Answered
on May 25, 2020
My player reads "bad disc" when i start it up with
It means that the laser head is no longer getting a good signal - the lens is dirty and you must clean it by using a cleaning disk : $10 at Walmart.
If the clean doesn't help then the dust has been baked on the lens - in that case you must replace the entire laser head. Find one in un its sold for parts, or discarded ones. If you can't find a replacement head then the un it is dead.
9/30/2010 10:54:28 PM •
Polaroid...
Answered
on Sep 30, 2010
It keeps reading "bad disk"
If your system continues to read bad disk each time,pls check if the disk is new,if not,I think it needs a change of lens or better still buy a new one
4/24/2010 11:15:26 AM •
Polaroid...
Answered
on Apr 24, 2010
CAN I BUY ANOTHER REMOTE TO MY PORTABLE DVD PLAYER
You may be able to find a universal remote that will work for it. You will need to verify that it works for polaroid dvd player. Most universal remotes have supported devices listed on their website or on the back of the box.
9/13/2009 4:10:32 AM •
Polaroid...
Answered
on Sep 13, 2009
It sais no disc when there is
Try cleaning the lens with a DVD Disc Cleaner or Methylated Spirit and a Q-tip, rub the lens slowly in a clockwise motion, leave to dry and put in a DVD, if it doesnt work try a CD but make sure they dont have any scratches or dust on them, if a CD works ( or not ) then your lens is knackered.
8/12/2009 9:42:40 AM •
Polaroid...
Answered
on Aug 12, 2009
It Loads but doesnt spin and said "no disc."
jon
8/12/2009 9:42:33 AM •
Polaroid...
Answered
on Aug 12, 2009
I get the message
ok best bet is that your laser (what reads the discs) in your laptop is dirty, use a cd/dvd cleaning disc to clean the laser, can buy them from most computing, music shops
6/29/2009 2:11:11 PM •
Polaroid...
Answered
on Jun 29, 2009
Dvd player movie never loads
The lens on the DVD player might be dirty. Try taking a q-tip and soak it in rubbing alcohol. Next, open the cover and look for the laser lens. This is usually a clear white plastic circle looking piece. Take the q-tip and clean the top of the laser lens but don't rub to hard. Let it dry for 10 minutes and see if the DVD will play. If not, then your DVD player is broken and needs to be serviced.
5/2/2009 2:15:23 AM •
Polaroid...
Answered
on May 02, 2009
Dvd plays upside down how to play normaly
To rotate the DVD screen display, hold down the MODE button or DISPLAY MODE button (depends on model) while a DVD is playing to turn the picture right-side up.
8/13/2008 9:06:15 PM •
Polaroid...
Answered
on Aug 13, 2008
