20 Most Recent
Vantec NexStar NST-D100SU Hard Drive Dock - 2.5/3.5 SATA to USB 2.0, eSATA Serial ATA, USB 2.0, eSATA Drive Case Questions & Answers
Vantec nexstar will not mount as removable
On windows seven there is no eject or remove safely in the main menu. Use mouse click <START> <Devices and Printers> find the device then right click and then select <Eject> or <Remove Safely>
Voil? you now can remove device without having to shut down computer.
My Nexstar 3 drive will not load. Any Suggestions?
Let's start with the basics:
1) Is the drive getting power; is the supply correct and the connection firm? Does the drive spin-up at all?
2) Is the data cable known to be good?
3) Is the port on the computer known to be good, mechanically and electrically?
4)Does the OS support this device, or does it require additional drivers?
If it worked before, 9 times out of 10 a bad connection somewhere is at fault. Even if software or data corruption is involved, the cause is almost always an intermittent connection.
