20 Most Recent
Polaroid LCD-2050 20 in. Television Questions & Answers
I have a Polaroid 20" lcd FLM-2011 , I just
It sounds like the power supply board is weak, Replace the bad electrolytic caps on the power board, or the power supply board. If you are not getting any video,then that could be the problem.
12/18/2010 8:37:16 AM •
Polaroid...
Answered
on Dec 18, 2010
Blue Screen w/ sound
I've tried many different things to isolate the problem, the only solution is to manually reset it to factory settings via menu button. If something goes wrong, like the menu button freezes turn off the monitor *Or unplug it, and retry to reset factory settings. Unfortunately you have to do this almost every single time you turn off/on the television.
5/22/2008 2:17:07 AM •
Polaroid...
Answered
on May 22, 2008
Polaroid TV working with constant red flashing light
If your Polaroid Roku TV is working fine but the red light is continuously flashing, it could indicate an issue that may need attention. Here are some steps you can try to troubleshoot the problem:
- Power Cycle:
- Turn off the TV and unplug it from the power source.
- Wait for at least 5 minutes.
- Plug the TV back in and turn it on.
- Check Remote Control:
- Ensure that there are no stuck buttons on the remote control. Press each button to make sure they are not stuck in the pressed position.
- Update Firmware:
- Check if there is a firmware update available for your TV. You can usually find this information in the TV's settings menu.
- Reset to Factory Settings:
- Perform a factory reset on your TV. This will erase your settings, so be sure to back up any important information first.
- Check for Physical Obstructions:
- Make sure there are no physical obstructions around the TV, particularly around the infrared sensor on the TV and the remote control.
- Contact Customer Support:
- If the issue persists and your TV is still under warranty, consider contacting Polaroid customer support for assistance. They may be able to provide additional troubleshooting steps or offer a solution.
- Professional Repair:
- If the TV is no longer under warranty and the issue persists, it might be advisable to consult a professional technician or a TV repair service to diagnose and fix the problem.
Always refer to your TV's user manual for specific instructions related to your model. If none of the above steps resolve the issue, it's recommended to seek assistance from the manufacturer or a qualified technician for further diagnosis and repair.
12/27/2023 10:15:57 PM •
Polaroid...
Answered
on Dec 27, 2023
