20 Most Recent
Cavalry Storage Cavalry CAXB 2TB USB 2.0 / eSATA Black External CAXB3702T3 Hard Drive Questions & Answers
Cavalry hard drive gets error message
click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software
hope this helps
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives.
When the bleu light does not go on, you have to assume the drive is not getting power.
If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone.
If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive.
If both don't work, it also could be inside the housing of the drive is something defect.
If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net.
Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
Error message says I don't
It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department.
-Alex
CAUO37500 Lite's on but nobody
im not sure how bad your hard drive is but if it works on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps also
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
How do I turn on video? Choose options from where?
It depends on the device or platform you are using to access videos. Some general options to turn on video include:
On a computer: If you are watching a video on a website, such as YouTube or Vimeo, click the play button on the video player. If you are using a video chat or conferencing software, such as Zoom or Skype, click the video camera icon to enable your webcam.
On a smartphone or tablet: If you are watching a video on a mobile app, such as YouTube or Netflix, tap the play button on the video player. If you are using a video chat or conferencing app, such as FaceTime or WhatsApp, tap the video camera icon to enable your camera.
On a television: If you are watching a video on a streaming device, such as a Roku or Amazon Fire TV, select the video you want to watch and press play on your remote control. If you are using a video game console, such as a PlayStation or Xbox, navigate to the video app and select the video you want to watch.It is also important to check if your device or platform has a setting to turn on the video, such as in settings of the app or device.
How to install more RAM (Model Number G US-6873)
Installing more RAM (Random Access Memory) in a computer can help improve its performance by increasing the amount of memory available for running programs and processing data. Here are the general steps to install additional RAM in a computer with the Model Number G US-6873:
- Turn off the computer and unplug it from the wall.
- Open the computer's case. This can typically be done by removing a few screws on the back of the case or by sliding a release latch.
- Locate the RAM slots on the motherboard. These will typically be long, thin slots with a small lever or tab on one end.
- Carefully remove any existing RAM modules from the slots.
- Make sure that the new RAM module is compatible with your computer and the motherboard.
- Carefully insert the new RAM module into the empty slot or slots, making sure that the module is oriented correctly and that the tabs on the module align with the notches in the slot.
- Push the module down firmly into the slot until it clicks into place.
- Close the computer's case, plug it back in and turn it on.
- Go to the computer's settings, then click on "System" and then "About" to verify that the new RAM has been recognized and is being used by the computer.
How to Fix QuickBooks Error Code 9997?
QuickBooks Error Code 9997 typically indicates a problem with the connection to your financial institution's website. To fix this error, try the following steps:
- Make sure your internet connection is stable.
- Check that the website of your financial institution is up and running.
- Clear your browser's cache and cookies.
- Try accessing your financial institution's website using a different browser.
- Make sure your QuickBooks software is up-to-date.
- Check for any recent updates for your financial institution's online banking services
- Try disabling any firewalls or antivirus software temporarily to see if that resolves the issue.
- If you continue to have trouble, contact QuickBooks support or your financial institution for further assistance.
