20 Most Recent
Nuance Dragon NaturallySpeaking 11 Premium with Headset & FREE CheckIt Diagnostics Voice Recognition... Questions & Answers
Trying to use the headset
Did you check the installed sound devices on the computer?
May be you do not have any sound driver installed on the computer,
Also check the device is not disabled from the control panel.
If you did not find the solution helpful. Try to search for the solution here... this has many solution to this problem.
Nuance and Dragon Naturally Speaking Support
What is the best voice recognition software for Windows 7
the voice recognition system built into windows 7 is quite good, however if you do not wish to use that, you might find Dragon NaturallySpeaking 11 Premium (199$) extremely good, or if that's not in your budget, Dragon NaturallySpeaking 11 Home ($99) is also well to do.Other than that, there is also TalkingDesktop($89) that is also quite good.
How to install Nuance dragon naturally speaking Customer Service?
Solution:
- Open Dragon NaturallySpeaking.
- Go to "NaturallySpeaking > Advanced > Manage Users."
- Click on "New".
- Enter a name for the user (e.g., John USB).
- From the Dictation Source drop-down menu, select "USB Microphone".
- Click on "Next".
- Follow the instructions in the Audio Setup Wizard to train the user profile.
http://nuance.custhelp.com/app/answers/detail/a_id/2389/~/how-do-i-setup-a-usb-headset-microphone-with-dragon-naturallyspeaking%3F
How to Install Nuance Dragon software your PC ?
To install Dragon NaturallySpeaking:
- Insert the first Dragon NaturallySpeaking CD into a CD-ROM drive. ...
- Provide the customer information, including the serial number supplied with the Dragon NaturallySpeaking installation.
- Choose the installation directory. ...
- Install Type Description: ...
- The Dragon NaturallySpeaking QuickStart option can be enabled.
http://nuance.custhelp.com/app/answers/list/kw/How%20to%20Install%20Nuance%20Dragon%20software%20your%20PC%20%3F/sno/0/session/L2F2LzEvdGltZS8xNTg2OTM4NDkyL3NpZC9mVTVqJTdFSXZqSjVEUFRyS1pxTTc2WTRJUHJCUTVWR3dsX09pRktSZ2JYak1TSFZFQ19JQVFRQlNOcWtSdkxFZWpCekhIOWlianVoU1hJdEVTeTBtZnBuRG1mZ2JIMUEweHEyOVBwTXgwcEtUbE1kSGhTT3kzTUQ2USUyMSUyMQ%3D%3D/search/1
My MECER xpression notebook laptop is showing a bios password and it doesn't allow me to press
It sounds like your MECER xpression notebook laptop is displaying a BIOS password prompt and you are unable to enter anything after entering the wrong password three times. You can try the following steps to resolve the issue:
- Try to remember the password you previously set for the BIOS. If you are unable to remember it, you may need to reset the BIOS password.
- To reset the BIOS password, you can try removing the CMOS battery from your laptop's motherboard for a few minutes and then reinserting it. This will reset the BIOS settings to their default values and remove any passwords.
- If removing the CMOS battery does not work, you can try using a BIOS password reset tool or contacting the manufacturer for assistance.
It's important to note that resetting the BIOS password may cause your laptop to lose some custom settings or configurations, so you may need to set them up again after resetting the password.
Undefined error code 87
Error code 87 typically indicates an invalid parameter or incorrect command-line argument in the context of Windows API calls. However, the context you have provided is related to changing the CMOS settings, which is related to the BIOS (Basic Input/Output System) and not to the Windows API.
If you are unable to change the CMOS settings, it may be due to several reasons such as the CMOS battery being low or dead, a hardware issue with the motherboard, or the settings being locked by the manufacturer or system administrator.
To troubleshoot this issue, you can try the following steps:
- Replace the CMOS battery: A low or dead CMOS battery can cause issues with changing the CMOS settings. Try replacing the battery with a new one.
- Check for hardware issues: Check the motherboard for any visible physical damage or loose connections that may be causing the issue.
- Clear the CMOS memory: Try clearing the CMOS memory by removing the battery and leaving it out for a few minutes, then replacing it and restarting the system.
- Contact the manufacturer or system administrator: If none of the above steps work, it may be that the settings are locked by the manufacturer or system administrator. In this case, you will need to contact them for assistance.
It's important to note that changing the CMOS settings can be risky and may cause stability issues with your system. So, make sure you know what you're doing and have a good reason for changing the settings before attempting to do so.
How can I download woozworld without bluestacks PLEASE
You can download Woozworld without Bluestacks by following these steps:
- Go to the Woozworld website (www.woozworld.com) and click on the "Play Now" button.
- Create a new account or log in to an existing account.
- Once you are logged in, click on the "Download" button at the top of the screen.
- Select the appropriate version of the game for your device (Windows, Mac, or mobile).
- Follow the instructions to download and install the game on your device.
If you are downloading the game on a mobile device, you can search for it in your device's app store (such as the Google Play Store for Android devices or the App Store for iOS devices) and download it directly from there.
Note that you may need to have sufficient storage space on your device and meet the minimum system requirements for the game to run smoothly.
Scan editor adapter unavailable
It's unclear what you're asking. Could you please provide more context or information about the issue you're experiencing with your MC9090?
Are you in pursuit of a trustworthy iOS app development partner to build a distinctive and interesting mobile app?
Yes, we are in pursuit of a trustworthy iOS app development partner to build a distinctive and interesting mobile app. We have a team of experienced developers who are well-versed in the latest iOS technologies and development tools. Our experts are committed to delivering an innovative and high-quality product that meets your business needs. We strive to make sure that your app stands out in a competitive market and provides an engaging experience for your users.
Serial number for Silverfast 8
The serial number for SilverFast 8 depends on the specific license and version of the software you have purchased. Typically, the serial number will be provided to you when you purchase the software or when you register the software with the manufacturer.
If you have lost or misplaced your serial number, you may be able to retrieve it by contacting the manufacturer's customer support team. They may require some information, such as your name, email address, and order number, to verify your purchase and provide you with the serial number.
It's important to note that sharing or distributing serial numbers for software is ******* and could result in legal action. Always keep your serial number safe and secure to avoid any issues with your software license.
My Karbon safe has locked because wrong password entered three times.How do I unlock it
If your Karbon safe has locked due to entering the wrong password three times, you will need to follow the manufacturer's instructions for unlocking it. Here are the general steps you can take:
Wait for a period of time: Karbon safes typically have a security feature that locks the safe for a certain period of time after three incorrect password attempts. Wait for the period of time specified in the instructions before attempting to unlock it again.
Use the backup key: Many Karbon safes come with a backup key that can be used to unlock the safe. Locate the key and use it to open the safe.
Contact the manufacturer: If you cannot unlock the safe using the backup key or you do not have a backup key, you can contact the manufacturer for assistance. They may be able to provide you with a master override code or other instructions for unlocking the safe.
It is important to note that attempting to force the safe open or tampering with it in any way could cause permanent damage to the safe and void any warranty or insurance coverage. Always follow the manufacturer's instructions and contact them if you need assistance.
