20 Most Recent Pentax Optio M85 Digital Camera Questions & Answers
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Pentax Optio M85... | Answered on Oct 01, 2017
Pentax Optio M85 Battery Charger, Home Travel Charger.The wall is plugged directly into the cable, AC car adapter - battery charging at home or in your car, very convenient.http://www.2deals.net/Battery-Charger/Pentax/Pentax-Optio-M85.html
Pentax Optio M85... | Answered on Dec 20, 2012
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101';
Pentax Optio M85... | Answered on May 17, 2011
Most of the time, Windows update is at fault. Pros avoid this problem by using a card reader for downloading their pics. typrice_144.jpg
Pentax Optio M85... | Answered on Feb 28, 2011
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery.
Never remove or insert a memory card while the camera is turned on!!!!!!
Pentax Optio... | Answered on Apr 13, 2018
Put it in the airing cupboard to dry out for 48 hours
Pentax Optio... | Answered on May 11, 2016
Hi. Your camera is too old to accept that big a card. The camera will let you know what size it will accept. Just keep putting larger sizes until it stops. Hope that helps.
Pentax Optio... | Answered on May 29, 2015
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
Pentax Optio... | Answered on Feb 06, 2015
The Pentax Optio WG-2 takes an OEM manufactured battery or one designed for it. Google "Pentax Optio WG-2 replacement battery" or do a Amazon.com search for the same and you'll get thousands of options where to buy.
Pentax Optio... | Answered on Nov 07, 2014
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Pentax Optio... | Answered on Sep 15, 2014
Most of the time the charge light will change from red to green when the battery is full.
Pentax Optio... | Answered on Aug 28, 2014
Buy a USB card reader take card from camera and use that to import pictures. Sadly I can't help without knowing full details of your equipment, camera, computer operating system, etc.
Pentax Optio... | Answered on Jul 28, 2014
Pentax Optio M85 Digital Camera Logo
9 questions posted
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
camera option m 5 pentax
  • Cameras
