20 Most Recent PIONEERPOS 15 Inch M5 PNT-M/2G 512MB 80GB XP SPKR [pin-km5axr100031] PC Desktop Questions & Answers
Click Start/My Computer and see if the CD Player is listed as a device. If so then either the CD you are trying to play is bad or the player is broken.CD Players sometimes can't read CD's that were created by someone and given to you. Try a store bought CD and see if it plays. If not, your player is broken and needs to be replaced.
PIONEERPOS... • Answered on Apr 04, 2012
My guess is it is a programming glitch of the ALT key correctiable by BIOS modification rather than physically addressing. Such fixes are tried at your own peril and without guarantee of working (or even the computer working) after such. https://aatayyab.wordpress.com/2019/12/19/when-a-key-on-a-computer-keyboard-gets-stuck-keyboard-codes-and-their-hex-scan-code-values/ https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/very-odd-0210-stuck-key-error/3885128d-6bb7-4442-a669-73b14bf58bff That said, I would be awfully tempted to try an alternative keyboard (a rather dodgy idea if it is a laptop).
Computers &... • Answered 6 hours ago
hi - we got disconnected (accidentally ended the chat session?)
for the light pattern that you have here are the related issues:
paper jams , obstructions , cover error
Canon's recommendation:
Resetting the Printer By resetting the printer'spower, the print bufferis cleared and certain sensors are reset. Ifthere is invalid data inthe buffer, or sensors are stuck in aparticular mode; errors may occur.Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplugthe printer's power cord for approximately 10minutes, and then plug itback in. If troubleshooting a communicationissue, reconnect the datacable (not applicable to WiFi, Bluetooth orInfrared).
  4. Turn the printer back on.
Note:Ifresetting the printer does not work, please attempt any othersolutionsthat appeared in your search results.If this is a hardwareerror on theprinter, the printer may need to be repaired.
Issue: Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Solution: The iP1700 may require repair
Unfortunately,the issue you describe seems to indicate that yourproduct may requirerepair service. If you feel your product mightrequire service, aTechnical Support Representative will be happy toanswer any questionsyou may have and explain the service optionsavailable to you. You cancontact us through the email link or phonenumbers listed below.
  • Obtain Support by Email
  • Fortoll-free technical support, please call 1 (800)828-4040 duringregular business hours (currently Monday-Friday 10:00a.m. - 10:00 p.m.EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON
The InstantExchange Warranty Program is available:
(1) only for certain printer, facsimile, multifunction, and scanner models;
(2) during the express limited warranty period for such products; and
(3) only in the continental United States, Alaska and Hawaii.
Sowe may better assist you, please make sure that you can accessyourCanon product and have the following information available whenyoucall:
  • Product model name and serial number.
  • Computer's operating system; for example Windows XP.
  • Message displayed when the problem occurred.
  • Steps you've already done to try to solve the problem.
For information regarding the Canon U.S.A., Inc. Limited Warranty, please click here.
Welook forward to helping you rectify the issue you are experiencingandare always available to provide any assistance you may need.
Computers &... • Answered 21 hours ago
The problem you are facing may be due to the corruption of system files. You could use the following troubleshooting methods and check whether they help in solving the issue. Solution 1: Reset the Windows explorer Step 1: Press Ctrl+Alt+Delete at the same time and choose to launch Task Manager. Step 2: Find Windows Explorer/Explorer.exe in the window and right-click on it. Choose End Task. Step 3: After that, navigate to File > Run New Task, type explorer.exe, and click OK. Step 4: Now, restart windows explorer and check whether the error persists. If the issue still persists try the below solution. Solution 2: Clean boot your computer Step 1: Press Win + Q and type in System Configuration. Step 2: Navigate to Gerneral, uncheck Load startup items option under Selective startup. Step 3: Now, turn to Services tab, select Hide all Microsoft services, and then click on Disable all. Step 4: Restart your PC to check if the problem persists or not. If the problem still persists after you have tried out the two solutions, you could refer to this article to learn other fleshed-out ones: 10 Solutions to Fix Windows Explorer Has Stopped Working Error
Computers &... • Answered Yesterday
To fix issues with your Echo device not responding:
  1. Make sure you're using the power adapter that was included with your device.
  2. Make sure you have an active internet connection.
  3. Check that your device isn't muted. ...
  4. For devices without a screen: press the Action button to see if your Echo device responds.
More items...
Amazon.com Help: Alexa Doesn't Understand or Respond to ...
https://thegeekpage.com/fix-this-application-requires-directx-version-8-1-or-greater-to-run-on-windows-10/
Computers &... • Answered 2 days ago
Are you using a discrete video card? If so, what is the make and model of the graphics card? Press Windows key + X Click Device Manager Expand Display adapters Right click the current display adapter Click Properties Click Driver tab Click Rollback driver if the option is available If not Right click the current display adapter Click Uninstall Check the box that says, "Delete the driver software for this device." Exit Device Manager Restart Go to Start -> Settings -> Update & security, then Check for updates and install any available updates. You might need to update the display driver from the manufacturer of your computers website. If that method fails to work, check out this article: 6 Best Solutions To Fix Computer Randomly Restarts On Windows
Here is a good post that can help you with downloading music on to Android devices. Basically you will need to download one of these apps and navigate to a website that has free music to download. Top Free Android Apps to Download Music mp3 downloader GetAndroidstuff
Computers &... • Answered 3 days ago
if you are using the PC's motherboard sound I would upgrade to a soundcard. they are relatively inexpensive and easy to install. www.pricewatch.com
This model DOES NOT connect to a computer. download the manual here. Press CTRL+F, type 'computer'. Nothing!
BP 3AG1 - Microlife AG
https://www.microlife.com > support > blood-pressure
BP 3AG1 Blood pressure monitor Model no.: BP 3AG1. Dimensions: 140 x 120 x 70 mm. Weight: 400g (including batteries) Voltage source: 4 x 1.5 V alkaline batteries; size AA or mains adapter DC 6V, 600 mA (optional)
connect it with lan cable to your laptop or desktop
have you forgotten password? if yes try resetting your router
  • Windows 7 - Windows 10 (64-bit versions)
  • A minimum of a 2 core CPU.
  • 1280x1024 min. screen resolution.
  • 4 GB RAM minimum.
  • Internet Connection or e-mail account (for License Registration)
above is system requirement. check if it matches you system
There are many converters out there. I would suggest using VLC converter because it supports many formats and there are Mac and Windows versions. Go to http://www.videolan.org/ to get this.
Computers &... • Answered on May 06, 2021
Your 80029C55 error code refers specifically to the PS3 being unable to read data from a USB device. Since it's formatted correctly and you're able to access data from it e.g. JPGs and MP3 files, it doesn't sound like a formatting issue at all, but instead an issue of power consumption.Aug. 6, 2019
PS3 - (Solved) Uncommon error (#80029C55) with HFW on ...
PIONEERPOS 15 Inch M5 PNT-M/2G 512MB 80GB XP SPKR [pin-km5axr100031] PC Desktop Logo
1 questions posted
Top PIONEERPOS Computers & Internet Experts
k24674
Are you a PIONEERPOS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PIONEERPOS Computers & Internet
Most Popular Question
im looking right pposx exe stealth touch
  • Computers & Internet
