20 Most Recent
Rockford Fosgate Power 1000BD Car Audio Amplifier Questions & Answers
It started cutting in &
It sounds like the amp is having problems internally. You should contact Rockford to find a place that can fix it.
Lights up no sound
Disconnect your subwoofer wiring from the Amplifier, and use a multi-meter to check for resistance, or an open line. The subwoofer should have resistance. If not, check the wiring inside your box. If the wiring checks out, replace the subwoofer. Also, check your RCA connection from the Head unit to the Amp. I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Need tool for amp
Some of the amps used tamper-resistant socket head cap screws. You can buy the nex bits from mcmaster.com. Try page 2753.
There are no fuses in it. Are you going to try to repair it yourself?
Amp overheating
You could just have a simple idling bias or dc balance alighnment thats needs attention. Always take care of the smaller problems before they grow as this problem could grow to where it pops your outputs , your speakers or the drivers. Try this before sending it in. 480-967-3565 Good Luck
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
