20 Most Recent Seagate 9w2874-500 200 GB Hard Drive Questions & Answers
5answers
My seagate 9w2874-500 will not
Don't be panic. you can try some data recovery software. You can seehttp://www.asoftech.com/adr/It tells the steps how to perform data recovery.If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
12/21/2013 7:20:35 AM • Seagate... • Answered on Dec 21, 2013
My computer sees that the
Hello, I suspect your external has not been assigned a drive letter and so cannot be mounted by windows. To confirm:
1. Open start menu, right-click my computer and click manage. Then click disk management
2. Check if your external is listed and if a drive letter has been assigned, if not:
3. Right click on your external, choose change drive letter and paths, click add and then assign a drive letter. Choose ok and you are good to go.
Other causes of this problem may be a hard-drive errors or a faulty cable.
7/8/2011 12:36:02 AM • Seagate... • Answered on Jul 08, 2011
I need a driver for
if you are having trouble with your drivers here is a general look at the drivers and how to update them if your computer came with a motherboard disc the drivers could be on it click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver hope this helps http://www.downloadatoz.com/driver/
5/17/2011 12:05:22 AM • Seagate... • Answered on May 17, 2011
I have misplaced the power
2/25/2011 4:06:45 PM • Seagate... • Answered on Feb 25, 2011
Where can I download the
Here is a website that you can download manuals from...
http://www.seagate.com/www/en-us/support/downloads/
12/9/2010 3:56:59 PM • Seagate... • Answered on Dec 09, 2010
Cord to external hard drive seem to be wearing
Check CYBERGUYS website.
11/4/2009 6:04:11 AM • Seagate... • Answered on Nov 04, 2009
Lost driver for Seagate 9W2874-560.
See this link on the Seagate site:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=3.5-inch_Pushbutton_Backup_and_SATA_(eSATA)_External_Hard_Drive_Support&vgnextoid=fb163b5ff0b8e010VgnVCM100000dd04090aRCRD
Check your model number (should be something like ST3200823A-RK) against the list.
6/9/2009 2:58:08 PM • Seagate... • Answered on Jun 09, 2009
Compaq armada stuck on help menu
try selecting safe mode, remove the software/or updates you recently installed
or choose last known good configuration.
If that does not work, you can choose F10 and restore your OS
2/2/2009 1:08:59 PM • Seagate... • Answered on Feb 02, 2009
I have placed a large amount of data on my Seagate 9W2874-500.
Yes, get the free version of this data recovery software from
http://www.deaddiskdoctor.com
Another one you can try if above fails:
http://www.pcinspector.de/file_recovery/welcome.htm
HTH,
Deboo
1/20/2009 7:36:25 PM • Seagate... • Answered on Jan 20, 2009
My system display bluescreen and say physical memory dump then restart everyday minimium 5times
there are some reesons for this blue screen,first check for error dump files in your system(hope you use windows OS),which may be stored to send error reports to Microsoft,second thing is your C: drive may be almost full,owing to many installed programs,third thing you may have low RAM memory.
10/10/2008 12:11:23 PM • Seagate... • Answered on Oct 10, 2008
How to delete backup on my seagate backup plus slim
Detailed steps to manage backup disk space
To delete old backups on Windows 7/8/10 using AOMEI Backupper, you need to set up Backup Scheme during the process of creating a backup. When your backup versions exceed the number of backup images files, AOMEI Backupper will delete older backup automatically. Step 1: Connect your Seagate Backup Plus drive or Central hard drive to the computer and make sure it can be detected by your computer. Step 2: Download AOMEI Backupper Professional, install and launch it. Step 3: Click Backup and File Backup subsequently Step 4: Choose the files and folders you want to backup and pitch on a path for it. Then, Click Schedule option and select Schedule Settingsfrom the following window. Step 5: Click Scheme option, tick Enable Disk Space Management and select whatever Scheme you need from the drop-down menu. Then, back to the main page of File Backup and click Start Backup. After that, your older backup will be deleted automatically when your file backups exceed the versions of backup image files.
2/26/2024 7:21:41 AM • Seagate... • Answered on Feb 26, 2024
Ive got a 8tb seagate its got a blinking blue light and wont connect to my Pc? Any help?
Did you initialize it?
7/3/2023 8:38:03 AM • Seagate... • Answered on Jul 03, 2023
Seagate Portable Hard drive 4TB, part number 2N1AP6-500
Hi, Please put your computer into safe mode before attempting to connect to the hard drive again. Safe mode turns some feature off when activated so whatever program is forcing the shutdown might have be paused when connecting to the external hard drive. Also, try connecting the hard drive to a non-laptop intermediary device and then connecting that device to your computer and attempting to access the hard drive folder within the intermediary drive. Thank you.
11/11/2022 2:11:28 AM • Seagate... • Answered on Nov 11, 2022
2answers
How to recover data from a dead Seagate external hard drive on my Computer?
Should be careful with the data file deposited on the Seagate external hard drive. your Seagate external hard drive might be dead or corrupted. In this situation, you might need to rely on data recovery software to get back data and files on the dead Seagate external hard drive. So you can rely on data recovery software to get back lost data and files when the Seagate external hard drive is dead and inaccessible. Data recovery hong kong technician provide the Ontrack EasyRecovery data recovery services are able to recover data and files from accidentally formatting, corruption, virus attack, dead, system crash under different situations Seagate external hard drive on Windows Computer. This data recovery software allows you to deep scan the dead Seagate external hard drive so as to find out almost all lost files with original quality in a short time. You can also rely on this software to recover files from dead/damaged Seagate external hard drive. The software supports to get more recover: Seagate External hard drive, data file, documents, PDF, Excel, photos, music, and videos any HFS, HFS, FAT, ExFAT, and NTFS format based data and file and more. It will recover data and file from all external storage devices that can be recognized by your Windows PC Computer/Laptop. Hope this helps you get to recover all your lost data and files from your dead Seagate External hard drive.
10/8/2021 1:02:33 PM • Seagate... • Answered on Oct 08, 2021
What enclosure is compatible with a Seagate Barracuda 7200.7 SATA Drive?
TRY LOOKING FOR TIGERDIRECT .COM THEY SELL STUFF FOR COMPUTERS
10/3/2021 8:21:41 PM • Seagate... • Answered on Oct 03, 2021
5answers
Need restore my RAW file system back to NTFS without losing any hard drive files?
There are two options for you to get your drive stuffs back right now: 1). Do not format this RAW file system external hard drive temporarily and plunge it to your PC. And then, choose and apply RAW external hard drive data recovery software to scan this drive and find your preferred drive files back as many as possible. 2). Directly consult some professional data recovery services from some data recovery companies or agencies. In the future, remember to save copies of everything important on at least two devices in case of any similar data loss issues.
1/5/2021 2:43:04 PM • Seagate... • Answered on Jan 05, 2021
I have seagate plugged in and attached to my computer. I downloaded the program but I get the message connect a dashboard enhanced drive to activate features ??
Can you please provide more detail on the program you are downloading, the model of drive, and model of computer?On the face of it, the program seems to be saying it is not compatible with the model of drive you have plugged in, or that the drive has been reformatted in a way that is not compatible. Does the drive show up in the File Explorer / Finder of the machine?after comment : ok, if you can drag and drop files onto it, then That means it is operational, and recognized by the system. The next question is why you can’t install the Seagate Desktop software. Where did you get the software from? Try going to Seagate Support and looking up your drive model, and doing a fresh download of the software they have for that model. Alternatively, there are other backup software packages available, Acronis, Aoemi, EaseUS, and others. You can find reliable downloads of utility software at downloads.com (CNET) or look for reviews from PcWorld or PCMagazine for their recommendations of the best paid and free backup software
10/20/2019 9:49:12 PM • Seagate... • Answered on Oct 20, 2019
Necesito controlador para Seagate medalist 4310
I need controller for (English please) in a computer,. or DVR or what, where does this HDD go? Medalist 4310 (ST34310A) built in 1999 (20 years old ) why use any drive this old. why? it's useless. my wild guess, is this you have a PC and ustated PC has SATA only ports (modern) and this old old HDD is PATA drive, with ribbon cable wide. and you think it can run on modern PC. well they do sell cards (PCI-e) that fit and work. 4.31GB is the size , holds about 1 top movie . are you going to boot from this drive, if yes, very complex answer I will skip here. (ask maker of card , if it can) newegg.com has them all, any thing you can dream of , is there. if you look. https://www.newegg.com/Product/Product.aspx?Item=9SIA4UB8ZU9127&Description=pci-e%2c%20pata%20IDE%20card&cm_re=pci-e%2c_pata_IDE_card-_-17Z-0007-00AF2-_-Product again, no PC stated, no OS stated. nor of booting is needed to the PATA relic drive. from 1999.
4/8/2019 1:42:01 PM • Seagate... • Answered on Apr 08, 2019
Seagate 9w2874-500 200 GB Hard Drive Logo
15 questions posted
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Seagate Computers & Internet
Most Popular Question
seagate 9w2874 500 will not
  • Computers & Internet
