20 Most Recent
Rockford Fosgate T15004 Car Audio Amplifier Questions & Answers
I have 4 10 inch
Here is the link on how to wire subs
http://www.crutchfield.com/S-cgSECUmngLm/learn/learningcenter/car/subwoofers_wiring.html
Reason for your battery being drained is becuz your alternator isn't able to keep up with the power distributed to your amps becuz you are pushing way too much power. I would recommend a bigger alternator, separate batter for your cap and amps so your battery isn't drained.... Yes I understand that the cap is suppose to hold the power but your electrical system wasn't designed to take such a power loss due to running your stereo.
MY ROCKFORD T15004. It worked fine until last
dampness probably is the issue , those components on the board are delicate to moisture . open cover and look in side on the amps board for any greenish white build up of corrosion on outputs , resistors ect .
Rockford Fosgate T15004 The Amp still powers up with the
Check you inputs to verify you have a signal coming in, if signal then check outputs try a speaker that you know is working and plug it in if that speaker plays then the subs/ or speaker wiring is bad, if it doens't play then you probably have a blown output transistor on the amp or possibly a terminal ground/positive has come loose on the inside..
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
