20 Most Recent
Rockford Fosgate T15002 Car Audio Amplifier Questions & Answers
What fuse and fuse breaker should i run with this
100 amp should do it. Put the fuse or breaker as close to the battery as possible. Beware of cheap round glass type fuse holders. If going with a fuse i recomment the ANL type. The ANL fuses are actually screwed to the fuse block and give a much tighter, more reliable connection.
2 12 p3d212 2 ohm hooking up to a rockford
Hello a_brake11,
The P325.1 is relatively small to power a pair of P3's. You'll only get 325 watts RMS at 2 ohms (162.5 watts per sub). The P3's power range is from 100-500 watts, so they will work, but don't expect them to be really loud.
For best power, your subs should be wired with the voice coils in series and then the 2 subs paralleled to the amp resulting in a 2 ohm load.
Hope this helps.
I have a Rockford Fosgate 1500 BD amplifier and terminals for the power cable will not loosen or tighten how do I fix it
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
