20 Most Recent eMachines EL1352G-01w (884483537679) PC Desktop Questions & Answers
would not recommend it but if the tower is very sturdy and doesn't have a flimsy cover it should hold the wait of the monitor without any problem just make sure not to set the monitor on the side where the mother board is because it may damage it if any kind of flexing is done in that area
eMachines... | Answered on Jul 20, 2017
jumper on what, Hard drive? is it the only one? what type hard drive is it, how many pins?
eMachines... | Answered on Jun 29, 2016
Modern computers don't need their hard disk to be defragmented.
Perhaps you better try to clean up your disk and registry, with a program like Ccleaner. Don't forget ti install Microsoft Security Essentials, to keep the viruses out. When you have memory problems, please also check the Hard disk for errors with property and Extra, now check.
eMachines... | Answered on Feb 11, 2015
You mean you don't have created a windows password reset disk before?
That' nothing. Windows Password Reset will help you to create a reset disk to reset your windows password.Only 3 steps:
Step1:Download and install Windows Password Reset .
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove your Windows Password.
eMachines... | Answered on Aug 14, 2014
your computer is probably full of junk such as maleware and or spyware, you can download malewarebytes here: http://www.malwarebytes.org/lp/lp4/01_r/?gclid=CPufy_i2pL8CFQmsaQodSGIAqQ and run it and see if it finds a lot of junk if it does clean it out and you should find your computer running better, and keep this in mind computers are like children if you don't take care of them they will well you can figure out the rest.
eMachines... | Answered on Jul 01, 2014
First off make sure to check how much ram your motherboard can use make sure the rams also have the same or it will use the lowest speed and besides that make sure you have enough slots and your good to go put them in and your motherboard should pick them up and your done and pls explain more . It's kind of confusing do u have 2GB and want to add 2 more or do u have 4GB excuse me if I don't understand your writing above?
eMachines... | Answered on Mar 20, 2014
You should write down your windows code usually located at the sides or at the back of your computer and call microsoft.The have an automated phone system for activating genuine windows,this will also verify your windows code and tell you if somehow you got scammed.
eMachines... | Answered on Jan 03, 2014
Yes this eMachine has 2 PCI Express slots provided they are not occupied.
You can check the specs from this WEB site.
http://reviews.cnet.com/desktops/emachines-el1352g-01w-sempron/4507-3118_7-34169004.html
eMachines... | Answered on May 12, 2013
Your desktop may already enjoy a wired broadband Internet connection, but a Wi-Fi connection will afford you greater latitude in Internet use.
Wires will not be necessary, so you can establish your PC in any room or area of your home or office and still stay connected to the Internet.
Fortunately, you only need a wireless router, broadband modem, and ethernet cable to make this Wi-Fi connection.
Disconnect your modem from the wall socket it's plugged into.
Connect the ethernet cable to the back of the modem.
There is a clearly marked ethernet port here.
This port will appear to be an oversized telephone jack.
Connect the other end of the ethernet cable to the ethernet port on the back of the wireless router.
This port will look exactly the same as the one on the rear of the modem.
Plug the broadband modem back up to the wall socket and wait for it to power on, initialize and detect its new connection to the wireless router.
Locate the manual that shipped with your wireless router.
Find the URL, or web address, that is contained within the pages of this manual.
This special web address is used to set up your router's network and security permissions.
Also, be sure to locate the default password provided within the pages of the manual.
Enter the URL into your web browser and allow the page to load.
When prompted, enter the password that you found within the instruction manual.
Begin setting up your new wireless network.
You will be asked for an "SSID," which is just a moniker for your new network.
This will be the name seen when the network is listed in an available network list.
Choose whatever name you like.
Select a password for your new network.
While encrypting your network is optional, it is highly recommended.
Along with the password, choose "WPA" security encryption.
"WEP" will also be an option but it is an older security protocol that is technologically inferior to WPA.
Click "Apply" to save your changes.
Click on the wireless icon on the right-hand side of the bottom toolbar on your PC's desktop. Select your network's SSID from the drop-down list.
Enter the password you chose for your network.
You will now be connected to WiFi Internet on your PC desktop and free to browse the Web.
Setting up a wireless network
http://windows.microsoft.com/en-US/windows-vista/Setting-up-a-wireless-network
eMachines... | Answered on May 05, 2013
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive.
eMachines... | Answered on Mar 17, 2013
When booting, try hitting F10 or F12 to access the system BIOS. then go to boot device and make sure its booting from hard drive first
eMachines... | Answered on Feb 02, 2013
If memory serves the optical drive swings out of the way.
I also, (All cables removed), lay a static free towel down on the table, and lay the computer on it's side, on the table. (Opening side up)
[Be SURE to follow Anti-Static Precautions BEFORE reaching inside your unplugged from power computer; and during working on it.
Make sure you align the Locating Notch of the Ram Memory module; with the Locating Lug in the ram memory slot, when installing.
Locks on each end of ram memory slot click, when the ram memory module is correctly installed.
For additional questions please post in a Comment.
Regards,
joecoolvette
eMachines... | Answered on Dec 16, 2012
be sure nothing on you keyboard or pressing any key
eMachines... | Answered on Dec 04, 2012
eMachines EL1352G-01w (884483537679) PC Desktop Logo
53 questions posted
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
EL eMachines
  • EL eMachines
Most Popular Question
keeps telling me windows not genuine
  • Computers & Internet
