The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
or
Ebay you can purchase a Password Unlock/Recovery For Windows 2000/XP/Vista/7 Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7 Buy It Now price: US $1.49 (Approximately AU $1.50)also
You need to prepare:1:A blank CD/DVD or USB flash drive2.A computer which can link to internet3.A program called Windows Password Recovery 6.0Get started with this 3 simple steps:Website: http://lost-password.net/products/windowspasswordrecoery.htmlStep 1 - Download windows password recovery utility and install it.Step 2 -Burn your Windows Password Reset CD:To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.Step 3 - Put in your newly created CD and remove your Windows password.hope it helps don't forget to vote
2 questions posted
326 Questions
158 Questions
