20 Most Recent Sony 55" XBR Series LED Ultra HDTV - XBR55X900A Questions & Answers
2answers
What cause res vetical line in my 4k sony Bravia TV?
Your tv has been knocked on the side.
5/4/2015 5:55:08 PM • Sony 55" XBR... • Answered on May 04, 2015
I am stuck on one channel on my sony TV. I went onto menu but do not see a channel fix area there to highlight.
Your channels come from your cable box or satellite IPTV box. When you change channels on the television, you are actually changing the box, unless you have an antennae. You need channel search in setup. Google make model manual They are all online
9/12/2021 11:08:17 PM • Sony Televison &... • Answered on Sep 12, 2021
We have an older Sony DVD player that will not play a Disney DVD it previously played just fine. Ordered another new one and same problem! All other movies are working fine?! Please help!
You could have ordered DVD disc's that are of a different region then that are not working on your DVD player or it could be fake DVD disc's then too. You should always order from reputable business then.
9/6/2021 1:05:10 PM • Sony Televison &... • Answered on Sep 06, 2021
Sony EVO9720 won't power up but does have power.
When you start talking about the TV having a fan this sounds like a plasma TV...If you want to spend a bunch of money on it take it to a service shop, plasma sets generally are not something the average somewhat technically minded person wants to try to fix, there are from 10 to 14 boards in your TV and literally every one can cause your issue
8/26/2021 12:32:55 AM • Sony Televison &... • Answered on Aug 26, 2021
2answers
What went out on my sister's tv
Most likely is a blown capacitor. Open it up, check, find the Service Manual, find the value of it, buy one, de-solder the blown one, and solder in the new one. Cross fingers it didn't take anything else with it.
8/20/2021 8:15:44 PM • Sony Televison &... • Answered on Aug 20, 2021
1999 Sony Wega rca video inputs all stopped working after disconnecting cable. Is there a way to fix this?
Do a factory reset to this set, and then check. To make it factory reset, you have to enter its service mode. If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done. NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important. Service mode entry procedure of almost all Sony TVs [LCD & CRT] are similar.
8/16/2021 5:35:00 PM • Sony Televison &... • Answered on Aug 16, 2021
Region unlock sony bdp s5500
These cannot be unlocked.
8/15/2021 6:26:16 PM • Sony Televison &... • Answered on Aug 15, 2021
2answers
What is cost of main board of Sony KLV-42EX410
ask Sony we do not know their pricing
8/14/2021 5:09:49 PM • Sony Televison &... • Answered on Aug 14, 2021
I have a onn dvd ONA19DP005 an am wanting to us my sony universal remote whats the code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ https://homehol.blogspot.com/
8/11/2021 2:57:23 PM • Sony Televison &... • Answered on Aug 11, 2021
2answers
SONY LED TV MODEL - KDL-40W900A .MOTHER BOARD IS DAMAGED. REPLACEMENT COST 8000-10000 INR. CAN ANY ONE SUGGEST IF REPAIRING MOTHER BOARD IS POSSIBLE?? AND WHERE IN MUMBAI ?ANY CONTACT DETAILS ...
Mother board repairing at component level is not possible to Sony. It is best to replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
8/11/2021 7:34:29 AM • Sony Televison &... • Answered on Aug 11, 2021
DVD player. Why is it displaying t lock and the mechanism not ejecting?
Check the micro switches for the eject system
8/10/2021 6:49:18 PM • Sony Televison &... • Answered on Aug 10, 2021
Hi can you send me a tv diagram for sony tv model
I will send you the Service manual,by which you can easily locate circuit diagram.Let me know
8/8/2021 2:35:15 PM • Sony Televison &... • Answered on Aug 08, 2021
What causes pixelation while streaming?
Low input signal will cause pixilation
8/8/2021 12:23:10 PM • Sony Televison &... • Answered on Aug 08, 2021
Lightening strike on my TV
Seems that your TV is under service warranty. Contact the authorized service center for Sony. Probably, its main power board have the fault. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview by mobile. Mobile View has no search box.
8/2/2021 1:40:21 PM • Sony Televison &... • Answered on Aug 02, 2021
Hello, I have a Sony xbr55x810c that was told needs a new main board, it does not turn on with remote or switch on back, no light at all, has anyone had same problem and how did they resolve it?
Have you tested the various power supply voltages to see if it's actually the power board that's bad
8/1/2021 7:33:05 PM • Sony Televison &... • Answered on Aug 01, 2021
Codigos de sony RM Y173 para tv HAIER
Hola codigos para programar un televisor sony kv21xtR3
7/28/2021 6:42:48 PM • Sony Televison &... • Answered on Jul 28, 2021
Sony 55" XBR Series LED Ultra HDTV - XBR55X900A Logo
2 questions posted
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
cause res vetical line in 4k sony bravia
  • Televison & Video
