20 Most Recent Peerless WV-DV-04, Oil Fired, Hot Water Boiler, Taco 007 Pump, Riello BF5 Burner Up to 2,000 Ft Altitude - 182,000 BTU Questions & Answers
Need wire diagram from the hot wires feeding a
Dean,What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
11/5/2013 10:25:00 PM • Peerless... • Answered on Nov 05, 2013
Wiring Diagrams
Check out this sitewww.peerlessboilers.com/Products/ResidentialBoilers/SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
10/18/2013 4:45:28 AM • Peerless... • Answered on Oct 18, 2013
How to change 2016 Toyota 4runner air conditioner from Celsius to Fahrenheit
Follow these procedures to convert the air conditioning unit in your 2016 Toyota 4Runner from Celsius to Fahrenheit: Engage the ignition and verify that the air conditioner is on. Push the "Menu" button on the control panel for the air conditioning. Use the up and down arrows to pick "Display," then press "Enter." Choose "Units" using the up and down arrows, then click "Enter." Choose "Fahrenheit" using the up and down arrows, and then hit "Enter." To exit the menu, press the "Menu" button a second time. After completing these instructions, the air conditioning unit in your 2016 Toyota 4Runner should display Fahrenheit rather than Celsius. Please note that these methods may differ slightly depending on the model and year of your Toyota 4Runner; if you encounter any difficulties, you may choose to consult your vehicle's owner's manual or contact a Toyota dealership for assistance.
3/21/2023 2:17:52 PM • Heating &... • Answered 6 hours ago
RITETEMP VENTLESS FIREPLACE MODEL RTN250TE. What is the BTU of the Ritetemp RTN250TE please?
Question edited for clarity. Add 2 zeros to the model number. 25,000 BTU https://www.google.com/search?q=ritetemp+RTN250TE+how+many+BTU ..
3/20/2023 4:00:56 PM • Heating &... • Answered Yesterday
4answers
Building New Home - Advice Needed
Go for one of the big makers like Trane or Carrier. I have used a Fujitsu unit and have had some issues. One of the best ways to find a local contractor is to ask on the local Facebook group because any recommendations are based of experience. There are some 5 star recommendations in the link for Chattanooga. https://www.google.com/search?q=Chattanooga+TN%2C+Home+heating+installers ..
3/19/2023 9:47:49 PM • Heating &... • Answered Yesterday
Why petra package unit didn't start after change fan
There could be several reasons why a Petra package unit did not start after a fan was changed. Here are some possible causes:
Wiring issues: When changing the fan, it's possible that a wire was disconnected or connected improperly. This can prevent the unit from starting. Check the wiring connections to make sure they are secure and in the correct location.
Capacitor failure: The capacitor is an electrical component that helps the fan motor start and run. If the capacitor is faulty, the fan may not start. Check the capacitor with a multimeter to make sure it is within the acceptable range of values.
Motor failure: If the motor has failed, the fan will not start. Check the motor with a multimeter to see if it is receiving power and if it is within the acceptable range of values.
Thermostat issues: The thermostat may not be sending the correct signals to the unit to start up. Check the thermostat and make sure it is set to the correct temperature and mode of operation.
Circuit breaker tripped: Check the circuit breaker to make sure it hasn't tripped. If it has, reset it and see if the unit starts.
Control board failure: The control board is the brain of the unit and controls all of its functions. If the control board has failed, the unit may not start. Check the control board for any signs of damage or malfunction.
If none of these solutions solve the problem, it may be best to consult a certified technician who can diagnose and repair the issue.
3/18/2023 1:47:08 PM • Heating &... • Answered 3 days ago
Voltas 1 ton A/C wiring complete mouse demeg re wiring model?
The exact wiring requirements for a Voltas 1 ton A/C model will depend on the specific model and should be provided in the installation manual. If you do not have the installation manual, please contact Voltas customer service for assistance.
3/17/2023 11:11:35 AM • Heating &... • Answered on Mar 17, 2023
Speed queen commercial dryer model #STD32DG serial# DTCK**********
If the flame on your Speed Queen commercial dryer model STD32DG goes out 10 seconds after start-up and does not come back on, it could be due to a few different reasons. Here are some things you can check to troubleshoot the issue:
  1. Check for obstructions: Make sure the dryer's exhaust vent is not blocked by lint or other debris. This can cause the dryer to overheat and shut off the flame prematurely.
  2. Check the gas supply: Make sure the gas supply to the dryer is turned on and the gas valves are not clogged. You may need to call a professional to check the gas lines and valves for any issues.
  3. Check the igniter: The igniter is responsible for lighting the flame. If it's not functioning properly, it can prevent the flame from staying lit. You can check the igniter with a multimeter to make sure it's getting the proper voltage.
  4. Check the flame sensor: The flame sensor detects the heat from the flame and tells the control board to keep the gas valve open. If the sensor is dirty or defective, it can cause the flame to shut off prematurely. You can clean the sensor with a soft cloth or replace it if it's defective.
  5. Call a professional: If none of the above steps work, it's best to call a professional repair service to diagnose and fix the issue. They can safely and effectively troubleshoot the issue and get your dryer running again.
Remember to always prioritize your safety when attempting to troubleshoot any issues with your appliances. If you're unsure about how to proceed, it's best to seek professional help to avoid causing any further damage or risking your safety.
3/15/2023 8:05:15 PM • Heating &... • Answered on Mar 15, 2023
3answers
My ac is not blowing cold air. There is cold air existing evaporator coil and even though the fan is moving there is no air coming from vents anywhere in the house.
The fan motor is the most likely culprit for this issue. Since the fan motor is in charge of forcing air through the vents, it will not function properly if there is no airflow. You must look for any symptoms of corrosion or deterioration on the fan motor in order to identify the problem. You will need to replace it if it seems to be broken or defective. While loose or damaged wires can result in the motor malfunctioning, you should also examine any electrical connections that link to the fan motor.
3/15/2023 2:01:49 PM • Heating &... • Answered on Mar 15, 2023
My A/C showing WIFI sign, what does it mean? And it trips for every 5 minutes and compressor restarts every 5 minutes. WIFI sign also appear on the remote. What does it mean how can I fix it please?
Question edited for clarity and make some sentences. All questions need FULL 'make mode (what it is)' as first 3 words. Is is a Samsung? It can't connect to the Internet. That is normally so you can control it from work and alter it when you leave. For the tripping, try disconnecting the power for an hour to reset it. That may need dealer service. The compressor restarting is called 'short cycling', but they should trip unless you have something else on the same circuit. The one that was in our bedroom would trip if my wife used the hairdryer in the bathroom. They draw a lot of power. As others have pointed out, it means that it can't reach the internet. I see this routinely on a certain network which requires additional credentials to be entered before giving full access.
My Samsung AC has a WiFi symbol near the on button. Does ...
and
What are Wi-Fi enabled air conditioners (ACs)?
Reliance Digital https://www.reliancedigital.in > Home > Buying Guides Enter the login credentials and you will be prompted to select the AC model. The app will then pair the phone with the air conditioner, via the Wi-Fi router.
3/14/2023 11:49:00 PM • Heating &... • Answered on Mar 14, 2023
2answers
Nordyne E3EB015H Furnace. I need to know what transformer originally came with unit please?
Check out the link for spares from that model furnace. Please note that all questions should have full 'make model (what it is)'. Not everyone can find information from snippets like I can ;>)https://www.google.com/search?q=nordyne+e3eb015h+transformer+replacement..
3/14/2023 4:32:56 PM • Heating &... • Answered on Mar 14, 2023
All my heat going out of inducer vent
It sounds like there may be a problem with the air distribution system in your furnace. Here are a few things you can check:
1. Check the air filter: A dirty or clogged air filter can restrict airflow, causing the heat to back up in the furnace and heat exchanger. This can cause the inducer motor to overheat and shut down. Replace the air filter if it is dirty.
2. Check the blower fan: The blower fan is responsible for distributing the heated air throughout your home. If the fan is not working properly, it can cause the heat to build up in the furnace and overheat the inducer motor. Check the blower fan motor and belt for any signs of wear or damage.
3. Check the ductwork: If the ductwork is obstructed or damaged, it can prevent the heated air from reaching your home's living spaces. Check the ductwork for any obstructions or damage and repair as necessary.
4. Check the pressure switch: The pressure switch is a safety device that ensures that the furnace is venting properly. If the switch is faulty, it can cause the furnace to shut down prematurely. Check the pressure switch for any signs of wear or damage and replace if necessary.
If you are unsure how to perform any of these checks or if the issue persists after trying these troubleshooting steps, it is best to contact a licensed HVAC technician to diagnose and repair the problem.
3/14/2023 7:26:11 AM • Heating &... • Answered on Mar 14, 2023
2answers
Where can I get parts for a Comfortstar GH-12000H?
The maker or the parts distributor
Comfort Star Heating Parts and Manuals - Guaranteed Parts
Guaranteed Parts https://www.guaranteedparts.com > HEATING Find OEM Comfort Star Heating Parts With Fast Shipping On All In-Stock Orders at Guaranteed Parts. Missing: 12000H ‎' Must include: 12000H
HOME - Comfort Star USA
Comfort Star USA https://comfortstarusa.com With over 50 years of combined experience we bring highest quality and reliability standards and are AHRI and ETL certified. Missing: GH- ‎12000H
3/14/2023 1:10:32 AM • Heating &... • Answered on Mar 14, 2023
What is line voltage polarity is reversed
When the line voltage polarity is reversed, it means that the electrical wiring in a circuit is connected in the opposite way than it should be. In a typical AC (alternating current) electrical system, the voltage should alternate between positive and negative 60 times per second in the United States (50 times per second in other parts of the world). If the polarity is reversed, the voltage will still alternate, but the positive and negative values will be switched.
Reversed polarity can be dangerous and cause problems such as equipment damage, electrical shock, or fire hazards. It can also cause some devices to malfunction or not work at all. Therefore, it's important to make sure that electrical wiring is installed correctly and that polarity is checked and corrected as needed. A licensed electrician should be consulted if you suspect that the line voltage polarity is reversed in your electrical system.
3/13/2023 12:27:13 PM • Heating &... • Answered on Mar 13, 2023
2answers
No pilot on my furnace to relight it.
Sometimes the knob presses in and sometimes turns as well. Google make model manual This is the only reference I can find, but it lights on demand https://www.doityourself.com/forum/water-heaters/513765-setting-valve-pilot-position.html ....
3/12/2023 11:26:25 PM • Heating &... • Answered on Mar 12, 2023
Peerless WV-DV-04, Oil Fired, Hot Water Boiler, Taco 007 Pump, Riello BF5 Burner Up to 2,000 Ft Altitude - 182,000 BTU Logo
2 questions posted
Top Peerless Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Peerless Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Peerless Heating & Cooling
Most Popular Question
need wire diagram from hot wires feeding
  • Heating & Cooling
