20 Most Recent
Mach Speed T3000 MP3 Player Questions & Answers
How do i download videos to it
If you have windows media player you would go to your libary and click on your videos and drag the video that you want to your sync list then press sync when you are done dragging all your videos to the sync list.
My TRIO T3000 screen is
Take the back cover off and take the battery out and leave it out for about 30 seconds and then put it back in and power it up that should reset the unit.
I hope my advice helps you out and if so please do not forget to rate/vote my place a testimonial for my advice.
Stormi
My screen on my trio
I just clicked the reset button on the side with the back of my earing for three seconds and the screen went black, so I powered it on, and now everything is fine. Try that :)
Screen frozen
use the reset button to reset it ..The device should be on when you do it ...and the reset button should be hidden in a hole somewhere at the side or at the bottom ...Just push in that hole with the sharp stylus ..and keep it pressed until restarts ..This should make it work ...
I hope this will be helpful ..
Wont turn on pressed the reset when it froze and
Press the Power ON/OFF slide button.
To power ON, push Slide UP & hold for 5 sec's
To power OFF, push Slide UP & hold for 5 sec's
If no go,
Use the Stylus and push into Reset hole, at bottom of device.
(not on back side, but at the bottom, where there is a single hole.
Press and hold for a second or two, or until it turns off/on.
Pushing Slide DOWN, put's it HOLD mode (make sure the slide
switch is Not in the Down position) is probably in Hold mode?
I've had this problem before and finally realized that I was putting it in
the hold mode every time, by pushing the Slide Power button, down.
Instead of UP.
Sceen froze
Take
unit.
IT DIDNT WORK N IM
If the player is new out of the box, it may need charging first. Connect the supplied USB cabe to the player and then connect the cable into the computer's USB port (boot up the computer first) and let it charge for approx. 6 hours.
The player should now work.
It froze when i took
The reset button is on the bottom of the device. It is a little hole, use a paperclip, push and hold for 10 - 15 seconds and it will reset. It happened to me the first time I used mine and I haven't had the same problem yet.
My screen is frozen i
I just opened my Xmas present a Trio T3000 and it froze on me while taking pics and it won't shut off what can I do?
We can not get the
had the same problem i had to restart media player then connect the usb plug then the mp3 so it would register with windows.
The touch screen wont function with touch of the
Touchscreen not working
Clean the screen with a microfiber polishing cloth.
Do not wear gloves while using the touchscreen.
Do not use the touchscreen with wet hands or immediately after applying hand
lotion.
Moisture affects touchscreen behavior in the same manner as it affects a
trackpad.
If you have a protective plastic sheet or film on the touchscreen, try
removing it, because it may be preventing the touchscreen from working properly.
The current application may be unresponsive; press and hold the Sleep/Wake button
on top of iPod touch for a few seconds until a red slider appears.
Then press and hold the Home button until the application quits.
If that doesn't work, turn the device off and turn it on again. Press and
hold the Sleep/Wake button on the top of the device for few seconds until a
red slider appears, and then slide the slider.
Then press and hold the Sleep/Wake button until the Apple logo appears.
If the device did not turn off, reset it. Press and hold the Sleep/Wake button
and the Home button at the same time for a least ten seconds, until the Apple
logo appears.
Please rate me
Eclipse Mach Speed Trio T2810C Charger?
To charge the player, simply connect it to a powered USB port, or external AC adapter. If you choose to use a third party adapter, please ensure that it is 5V and between 350 and 1000 mA , or 1amp
amazon has Excelity AC-DC 5V 1A Wall Charger Power Adapter with Plug 5.5 x 2.5mm / 5.5 x 2.1mm $9.00
Personally i would use computer charging for USB ports.
