20 Most Recent Toshiba Satellite C655-S5068 Notebook Questions & Answers
A laptop doesn't use a SIM card. SIM cards are for mobile phones and external routers, like a dongle.
Please explain what it is you wish to do and to exactly what.
Toshiba... | Answered on Sep 01, 2015
Download manual here: https://support.toshiba.com/support/search?search_query=manuals
Toshiba... | Answered on Feb 06, 2015
In short, yes you may have disabled it by shutting down services. I believe what you are looking for is the Value Added Package that is pre installed on toshiba computers. Check in programs and features if youre running windows 7 or in programs in windows xp. Both are under control panel. If you do not have the Value Added Package then go to toshibas website and download and install it.
Toshiba... | Answered on Nov 16, 2014
Your profile picture is stored in your My Pictures folder.
When you go to use a photo for your profile, that is where you get it from.
Now if you want a more specific answer, you have to give a more specific question..........
Such as;
How do I change my profile picture on FixYa.com?
How do I change my profile picture on Facebook?
How do I change my profile picture on Yahoo Answers?
How do I change my profile picture on America's Most Wanted?
(OH, I'M JUST KIDDING <- on the last one, geez!)
Please post back in a Comment.
Regards,
joecoolvette
Toshiba... | Answered on Oct 30, 2014
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Toshiba... | Answered on Jun 23, 2014
Try the Fn+F8 key. if you look at the F8 key closely you can make up a wireless icon. This should enable / disable the wireless antenna.
Toshiba... | Answered on Oct 15, 2013
You should be able to do it through the control panel. There should be a wireless icon depending on what version you have.
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Toshiba... | Answered on May 22, 2013
you can download your required drivers from HERE
Toshiba... | Answered on Apr 24, 2013
"kiosk mode'? Can you explain? Have you tried unplug, remove battery, plug in, reboot?
Toshiba... | Answered on Feb 25, 2013
If your TV has a VGA computer input connector, the you can connect a VGA cable from the TV to the video port on the Toshiba laptop.
Toshiba... | Answered on Jan 27, 2013
For most browsers you go into settings and there is a section for homepage in it. Add the homepage there. (google chrome makes it super simple)
Toshiba... | Answered on Jan 10, 2013
try to do a recovery ,
and dont install a lot of programs
Toshiba... | Answered on Dec 05, 2012
Click Start/Control Panel/Keyboard/Hardware Tab/Properties/Power Management/Make sure box is not checked that says "Allow computer to turn off this device to save power".
or
Hold FN then hit F11 key to enable it
Hold down the RIGHT Shift key for at least 8-10 seconds and that should disable it.
hope this helps
Toshiba... | Answered on Sep 18, 2012
things a pos are you entering it in a show ?
Toshiba... | Answered on Sep 10, 2012
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Toshiba... | Answered on Jul 31, 2012
Sounds like the HDD password or Bios password got set.
You may need to talk to the person who set that password to be able to finish booting up the computer.
If that person is not available - you can call the Toshiba 1-800-457-7777. They may want to charge you for the over the phone support - but they should be able to walk you through how to get around the Bios or Hdd password if that is indeed your problem.
Toshiba... | Answered on Jul 26, 2012
Sounds like you need to replace the laptop's power cord/charger.
Toshiba... | Answered on Jun 28, 2012
Toshiba Satellite C655-S5068 Notebook Logo
70 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite c655 hinge replace
  • Computers & Internet
