20 Most Recent Cisco Catalyst 2960-48PST-L - Switch - 48 Ports (V09362) Category: Network Switches Questions & Answers
flash_init first, then load_helper should work.
Cisco Catalyst... | Answered on May 13, 2017
Hi
I have checked and no data found for that S/N
Thanks
Cisco Catalyst... | Answered on Nov 26, 2014
Hi
Instructions
telnet to the IP address of the Cisco switch
Enter the telnet access password for the Cisco swict when requested, and then the "Enter" key.
Type "enable" at the command prompt, and then the "Enter" key.
Enter the Privileged Exec password when requested at the command prompt, and then the "Enter" key. Then enter "configuration terminal" at the command prompt, and then the "Enter" key.
Type "interface fastethernet0/1," replacing the "fastethernet0/1" with the name of an interface in which you wish to enable PoE, and then the "Enter" key. Then, while in interface configuration mode, type "power inline auto" and then the "Enter" key. Repeat this step for each interface in which PoE is required.
Type "end" at the command prompt and then the "Enter" key, copy running-config
Below is some commands to run, I don't have any power on the interface but this will show you if this is working...
SW1#sh power inline fastEthernet 0/1
Available:360(w) Used:0(w) Remaining:360(w)
Interface Admin Oper Power Device Class Max
(Watts)
Fa0/1 auto off 0.0 n/a n/a 15.4
Run this command to see the interface is up.....
SW1# sh interface fastEthernet 0/1 ' in protocol
FastEthernet0/1 is up, line protocol is up (connected)
SW1#sh cdp interface fastEthernet 0/1
Encapsulation ARPA
Sending CDP packets every 60 seconds
Holdtime is 180 seconds
Thanks
Fuel Temperature Sensor "B" Circuit High Input
- Faulty Fuel Temperature Sensor
- Fuel Temperature Sensor harness is open or shorted
- Fuel Temperature Sensor circuit poor electrical connection
Cisco Catalyst... | Answered on Aug 29, 2014
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
Cisco Catalyst... | Answered on Jun 20, 2014
    these are the popular firewall for recent days:
    ·Packet filtering firewall
    ·Circuit-level gateway
    ·Stateful inspection firewall
    ·Application-level gateway (aka proxy firewall)
    ·Next-generation firewall
Cisco Computers... | Answered on May 28, 2020
  • Packet filtering - ...
  • Stateful filtering - ...
  • Routing support - ...
  • Transparent firewall - ...
  • AAA support - ...
  • VPN support - ...
  • Supports IPv6 - ...
  • VPN load Balancing -
Cisco Computers... | Answered on May 13, 2020
DO NOT CALL FAKE NUMBERS OR GO TO FAKE WEBSITES. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website.
Cisco Computers... | Answered on Oct 21, 2019
Su mensaje no califica como una pregunta o consulta para un problema, intente en otro lugar
NO HAGA ESTE SITIO CON SU BASURA
Lleve su BASURA a otro lado
Su mensaje califica como SPAM
Cisco Computers... | Answered on Oct 20, 2019
Your message does not qualify as a question or query for a problem, try somewhere else
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Cisco Computers... | Answered on Oct 19, 2019
ACURTNADA, Your message does not qualify as a question or query for a problem, try somewhere else
Warning SCAM - DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
Warning! This is a SCAM - DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
Cisco Computers... | Answered on Oct 18, 2019
Warning! This is a SCAM-- DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
Warning! This is a SCAM DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
Warning! This is a SCAM -- DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
Warning! This is a SCAM -DO NOT CALL THESE NUMBERS. These phony support numbers send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
Cisco Catalyst 2960-48PST-L - Switch - 48 Ports (V09362) Category: Network Switches Logo
3 questions posted
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Jax Planet
Jax Planet
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Catalyst Cisco
  • Catalyst Cisco
Most Popular Question
load helper unknown command
  • Computers & Internet
