20 Most Recent D-Link DIR-815 Xtreme N Wireless 802.11N Simultaneous Dual Band Router With 4 Port Gigabit Switch Questions & Answers
Contact D-link support number 1-888-494-1155 (Toll-free) usa and find instant help by expert D-link technicians.
D-Link DIR-815... | Answered on Mar 06, 2018
Login into you router using your browser (connected by a LAN cable) and under the settings section you should see facotry reset.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
D-Link DIR-815... | Answered on Jan 06, 2017
You may have to do a full factory resent. Try a hard reboot (turn off the on) of the router. If not try a factory reset that you should be able to do using the admin functions in the settings. Of course you will have to set-up you router from scratch but this may solve your password issue.
Enter the username (admin) and password (blank by default), and then click Ok
D-Link DIR-815... | Answered on Apr 28, 2014
Your throughput (speed) is limited by the speed of the service from your provider. Additionally, this speed is divided or shared with every device connected via network cable and devices that are connected wirelessly, too.
To make matters worse, while the wireless N standard provides a faster speed, it only does so at a closer distance. When further away from the router, you may actually get better speed by connecting to the G side of the router (assuming you have G enabled).
Proper router configuration is key. Make sure you haven't locked it down to a slow speed. Install additional wireless access points or upgrade antennas with those that offer higher gain to provide good coverage in your home / space. Locate the wireless routers and access points closest to the areas these drevices will likely be used. Avoid installing in basements, behind brick and concrete walls. Aluminum siding can thwart a signal pretty well, too. Unplug / replace cordless phones that run on 2.4GHz - they can rob bandwidth from your router in the form of interference. Select Ch 1, 6 or 11 for the least interference from other wireless devices as long as they are not already in use by someone close by. Protect your WiFi by NOT broadcasting your SSID and be sure to lock it down with WPA or WPA2 security and a password that does not appear in the dictionary. This will help keep others from stealing your WiFi bandwidth.
All of these suggestions will either increase your throughput / speed or provide additional security and prevent others from stealing your bandwidth. I hope they help!
D-Link DIR-815... | Answered on Apr 24, 2013
JUST PUT THE ADDRESS ON THE SEARCH BAR
D-Link DIR-815... | Answered on Feb 04, 2013
Yes, try setting the router to a higher channel. Router default settings are suffer from interference from cordless land line phones, up to a mile away.
D-Link DIR-815... | Answered on Dec 01, 2012
It may not be your router, but your ISP data throttling your connection.
D-Link DIR-815... | Answered on Jan 19, 2012
Since this is a desktop PC that has Windows 7 OS, there might be a possibility that the issue is on your wireless adapter. As we all know, desktop PC's has no built in wireless card on them, so you need to install a wireless USB adapter on your PC. Of course, 3rd party wireless USB adapters has their own wireless utility to manage the wireless connection and that is where you need to put in the infos about your wireless connection. You didn't mention if on the 2nd part, is it asking you to re-type your wireless passphrase or is it asking you for a WPS pin.
D-Link DIR-815... | Answered on Sep 14, 2011
It's not the router. You have to turn off WiFi protected setup. Go to Advanced/WiFi protected setup/Uncheck Enable.I went through months of calling tech support and even replaced the unit thinking it was faulty. Works like a CHARM!
D-Link DIR-815... | Answered on Aug 05, 2011
Hi! have you check your wireless encryption methods does every machine support ex.wpa2? how about signal status is it fine? you can allso try to give ip addresses manually to make sure they are correct
D-Link DIR-815... | Answered on May 29, 2011
make sure you are connecting to your wireless network.
connect to your dlink from a computer to locate your password by opening your browser to
192.168.0.1
the default login/pass is admin/admin
click on setup and choose wireless settings
on the bottom you will see wireless security and the passphase which you will use your ipad to connect to your network.
D-Link DIR-815... | Answered on May 26, 2011
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
D-Link DIR-815... | Answered on Apr 06, 2011
press and hold the reset button on the back for 10 secs
D-Link DIR-815... | Answered on Mar 19, 2011
D-Link DIR-815 Xtreme N Wireless 802.11N Simultaneous Dual Band Router With 4 Port Gigabit Switch Logo
35 questions posted
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
need
  • Computers & Internet
