20 Most Recent ASUS P5G41-M Motherboard S775 Intel G41 mATX SATA Gigabit LAN (90-MIBAA0-G0EAY0KZ) Questions & Answers
Acer drivers
8/5/2014 2:09:49 PM • ASUS P5G41-M... • Answered on Aug 05, 2014
How to restore official windows
Restart your computer now as soon as you hit the power button keep on holding Alt key & keep on tapping F10 key Alt+F10 it will open the recovery console select full factory restore and follow on screen instruction
(Note:this will erase all datas on the computer)
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
2/14/2012 9:52:59 PM • ASUS P5G41-M... • Answered on Feb 14, 2012
3answers
My pc Shut Off Automatically after few min(5-6),when pc is in boot screen options or booting from O.S. CD"
I missed your question, anyways. as it seems there might be the reason of over heating. I would suggest just remove the heatsink apply proper heatsink paste on CPU and replace your heatsink and fan. heat must radiate properly.
11/30/2011 12:47:32 PM • ASUS P5G41-M... • Answered on Nov 30, 2011
2answers
I need ASUS X554L Usermanual
find link for asus x554l user manual https://www.asus.com/supportonly/X554LA/HelpDesk_Manual/
1/23/2022 7:23:59 PM • ASUS Computers &... • Answered 2 days ago
3answers
When I play dvds or watch videos on youtube the screen has a black border on both sides reducing the size of the screen
If you hit full screen on the youtube video and its not full screen, then it sounds like your monitor resolution is to low. Rt click on a place on your screen and pick screen resolution, then pick resolution and increase it.The first number is width, so say it's on 800x600 then go 1024x768
1/23/2022 7:23:52 PM • ASUS Computers &... • Answered 2 days ago
2answers
ASUS Router Login
at home or work or where (generic answer) RTM all routers have a free manual to read. and all of them tell you. must be wifi dead, after a move to new home? the manual on your router tell how to setup wifi. 2012 router https://www.manualslib.com/manual/415040/Asus-Rt-N66r-Dark-Knight.html?page=2#manual page 17 tells you how to access the routers setup [age
1/17/2022 1:11:35 PM • ASUS Computers &... • Answered on Jan 17, 2022
Asus EE pc 1005HA - all the three USB ports are not working?
Try rebooting.
1/17/2022 1:05:42 PM • ASUS Computers &... • Answered on Jan 17, 2022
Pls. front panal wiring diagramm for asus p4ds-vx
hi find link front panel wiring diagram for asus p4sd-vx https://www.google.com/search?q=front+panel+wiring+diagram+for+asus+p4sd-vx&sa=X&hl=en-US&biw=1366&bih=657&tbm=isch&source=iu&ictx=1&fir=0Rh1hvVyGnNKnM%252C5uIMIopNyomrBM%252C_%253B12LCAuLm_-YJYM%252CIbNzLUjch0OcAM%252C_%253BUuAquVX0QstuZM%252CxQvksBLcSfN7lM%252C_%253BJxNBDUI8AcQk5M%252C_AjCjcugs5ZHsM%252C_%253Bo72QEp15nYgyXM%252Clyf1sjBbo9TwGM%252C_%253BfCFEdzFkIzUrBM%252CunBOH_dNTh5MPM%252C_%253BlT57XNMQoz-fTM%252CunBOH_dNTh5MPM%252C_%253BkGCTVB121H_LPM%252Clyf1sjBbo9TwGM%252C_%253BkDcv2JVBwnzp0M%252CloQ2ZiB0YOzheM%252C_%253BXSf8yFbXnVxrZM%252CeKhQzXydABtV4M%252C_&vet=1&usg=AI4_-kQywYveAIgyr0GHx3rlo2kKycEkag&ved=2ahUKEwjU062M9an0AhW49nMBHclvAX8Q9QF6BAgOEAE#imgrc=UuAquVX0QstuZM
1/17/2022 12:38:47 PM • ASUS Computers &... • Answered on Jan 17, 2022
NEC DT700 series message: SIP Server Not Found on asus gt-ax11000
hi Our power went out recently, and ever since then, we have been without phones. On the terminal screen, the message "SIP Server Not Found" keeps popping up, and it continually attempts to reconnect, with no success. Help!
1/4/2022 4:45:41 PM • ASUS Computers &... • Answered on Jan 04, 2022
Asus mini tab not starting
Send it back. It is advertised as being 'strong'. You can try a soft reset, but in my view, unlikely to work. Press and hold the Power Button and the Volume Up button for 12 seconds.
ASUS Transformer Mini T102
https://www.asus.com > For-Home > Everyday-use > A... Built from strong but incredibly light magnesium-aluminum alloy, Transformer Mini is ultra-thin and feather-light, with a tablet that's just 8.2mm thin and ...
11/27/2021 7:17:54 PM • ASUS Computers &... • Answered on Nov 27, 2021
2answers
Tablet wont charge
Use a higher amp rated charger, (same voltage and polarity)..but I would suggest letting it complete it's charging cycle before trying to operate it..
8/14/2021 12:22:14 PM • ASUS Computers &... • Answered on Aug 14, 2021
Instruction manual ASUS X555LA-XO2625T
https://www.manualslib.com/products/Asus-X555la-5887002.html
7/12/2021 2:33:55 PM • ASUS Computers &... • Answered on Jul 12, 2021
Hello, My HDD led is not blinking on my PC but when I connected to my friends PC it worked. The green light is working perfectly when I connect it to the HDD led point it blinks but the red.
Look for the LED pins on your motherboard. One should be labeled HDD+ and one HDD- make sure the cables are plugged into these pins. Doesn't really which color wire to the + or - If it is plugged in the LED on your case could be bad. To test this will need a multimeter. Unplug the HDD cables from the pins. Set the multimeter to measure resistance the horseshoe 1 or 10 Ohms is fine. Stick a probe in each connector if the probes dont fit stick a paper clip in each hold and touch the probe to the paper clips. Dont let the clips touch. If you get no reading then the LED probably burnt out. If the LED tests ok you can leave it unplugged and turn on the computer. Set the multimeter to 10 Volts. Touch the red probe to the HDD+ pin and the black probe to the HDD-. DO NOT TOUCH BOTH PINS WITH ONE PROBE OR YOU WILL SHORT IT. Be careful... If you don't get a reading then there is no voltage making it to the pins.
7/12/2021 11:29:09 AM • ASUS Computers &... • Answered on Jul 12, 2021
Manuals mother board
Did you try manuals.com?
6/19/2021 2:09:53 PM • ASUS Computers &... • Answered on Jun 19, 2021
ASUS P5G41-M Motherboard S775 Intel G41 mATX SATA Gigabit LAN (90-MIBAA0-G0EAY0KZ) Logo
Popular Tags
5 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Ekse
Mehandi Husain ...
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
pc shut off automatically after few min
  • Computers & Internet
