20 Most Recent Mitsubishi WD-82838 DLP TV Questions & Answers
could be a color wheel or a fan, try to locate source of sound.
Mitsubishi... | Answered on Sep 03, 2012
An update can cause issues
Most of these sets have two different resets done with the remote--the soft one on most but not all is with set on: Menu, 1,2,3 enter.
I am not speaking about the reset button on the set if it has that but a remote reset with Mitsubishi remote.
The hard reset (everything back to factory) uses a 4 digit number code
see if 1,2,3 helps or not---I doubt once upgrade done it will be easy to go back---Mitsubishi used to mail out a upgrade---seen more than a few sets with suddenly new issues after the upgrade.
Mitsubishi... | Answered on Mar 30, 2012
sculin,
Certainly a new one would solve the problem but from what you have said it would seem that yours should be reaparable. The only question would be whether it would be worth fixing if it costs alot to fix. Putting a large amount of money in a twenty year old set is usually asking for trouble. You said that the unit has a loud hum. Sounds like a low voltage power supply problem. I have a tip at
http://www.fixya.com/support/r6396176-projection_tv_troubleshooting
which will walk you through the troubleshooting process and should help solve your problem with the least amount of money.
Thanks for using FixYa and for the great rating.
hardrocko
Mitsubishi... | Answered on Apr 05, 2011
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview/
Mitsubishi WD... | Answered on Jul 10, 2018
Basing the replacement of the board on the clicking sound of a relay trying to close is not a safe bet. The first thing you need to do is check the bulb. Then there is a ballast board and then the Power supply board. Parts might be hard to find. Use the website I listed to see what part numbers are then google it or look on eba or amazon for those parts. Mitsubishi WD 60C8 TV Parts
Mitsubishi WD... | Answered on Jan 18, 2018
Most likely a fuse blew when the lamp blew, there is internal fuses on the power supply board on these mitsubishi's, if the fuse is ok though then most likely another component somewhere failed.
Mitsubishi WD... | Answered on Jan 02, 2018
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mitsubishi WD... | Answered on Mar 27, 2017
Mitsubishi WD-82838 DLP TV Logo
12 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
mitsubishi wd 82838 tv turns off itself
  • Televison & Video
