20 Most Recent
Samsung RMC30C2 Remote Control Questions & Answers
I recently bough a Samsung
Sorry Amn_qaisar, but the dual display is only offered on the C9000 TV's. There are two types of remotes that look identical. The RMC30C1 and the RMC30C2. The RMC30C1 has the twin display feature and was specific to the C9000 samsung TV. The TV, not the remote, has the dual tv tuner which allows the signal to be sent over WiFi to the remote. So, even if you were to buy a RMC30C1 remote you still would not get the dual picture your seeking.
What is the difference between
They are pretty much the same except the C1 is designed for the 9000 series TVs and has a twin screen button whereas the C2 is for the 7000 / 8000 series Samsung HDTVs and has no twin button.
How can I connect the RMC30C1 Samsung Remote
No simple answer. I have the series 9 samsung.
Basically you need to connect the tv to the internet, and the remote control to the internet and then connect the remote to the tv. There are a few other ways but this is what I did for my Series 9 TV: Before you start check your wireless internet security number for your broadband router. If unsure check the instructions that came with your wireless router as you will need to type in the internet address and setup wireless security key, otherwise your exposed to other people using your broadband download.
Step One: Menu setting on TV go to PlugPlay- Network - set it up. To find Menu TV Control on remote, flick your finger right to left to scroll to new hidden screen - menu appears! Step Two: Test network connection, (you should set up wireless security (WEP/WAP) to match your broadband security key) Step Three: Services Tab/Setting icon/remote settings/network/wait until it finds network/select network/add security internet WEP/WAP Key - check IP Service Provider if unsure. When Remote is connected to the internet tap bottom right button to connect tv. Tab appears on the tv 'allow or not allow remote' select allow using the TV navigation button. Simple really. Mike
Samsung 55 TV White vertical patches?
It sounds like you might be dealing with backlight bleeding or an issue with the LED backlighting in your TV. This can sometimes occur over time due to normal wear and tear or manufacturing defects. If it started as a faint single brighter section and has now expanded to four, it's likely a hardware issue. While it may not be an easy fix, contacting the manufacturer's customer support or a professional technician would be a good next step to diagnose and possibly repair the problem. If you'd like, you can share the pictures for a more accurate assessment.
4/14/2024 7:29:30 PM •
Samsung...
Answered
2 days ago
Samsung un55nu6950fxza TV
These LEDs are very susceptible to static electricity damage. What happens when they get zapped is a tiny threading fault starts in the LED crystal. The aluminum contact metal starts migrating into the crack, makes it wider and longer, and eventually goes all the way through the LED and shorts it out. When that happens, the metal overheats and burns out the LED so the entire string goes dead.
What this means for you is that the original LED may have been may have been zapped at the factory. The replacement strip likewise, or when it was removed from another TV (if it is a used part), or when you put it in. It should have been in anti-static packaging. You have to be very careful not to touch any of the circuitry on the LED strip, and make sure you ground your hand to the TV metal both before picking up the LED strip and right before connecting the strip to the TV. Better yet, use an anti-static wristband connected to the TV frame.
It is possible that the LED driver for that string is pushing too much current, but that's not likely. You would probably notice that part of the screen is unnaturally bright.
2/5/2024 6:37:37 PM •
Samsung...
Answered
on Feb 05, 2024
Brand new Samsung 77 OLED tv. Got knocked off the stand and fell on and bent the lower corner
It sounds like your TV has a display issue, likely caused by physical damage to the screen due to the bend. Repairing a damaged screen can be quite expensive, often nearing or exceeding the cost of a new TV, especially for larger screens like the one you described.
Here are a few options you might consider:
- Sell it as is: You can try selling the TV in its current condition, clearly describing the issue with the display. Some buyers may be interested in purchasing it for parts or attempting a repair themselves.
- Attempt a DIY repair: Depending on your technical skills and willingness to take on the challenge, you could try to repair the TV yourself. However, this can be risky and may void any remaining warranty. There are online tutorials and replacement parts available, but again, this route requires some technical expertise.
- Professional repair: You could contact a professional TV repair service to get an estimate for repairing the screen. Be sure to weigh the cost of repair against the potential selling price of the TV after it's fixed to determine if it's worth the investment.
- Sell for parts: If repairing the screen is not feasible, you could dismantle the TV and sell its components individually. Some parts, like the internal circuitry or casing, may still hold value to electronics enthusiasts or repair professionals.
- Trade-in or recycle: Some retailers offer trade-in programs where you can exchange your old electronics for store credit or discounts on new purchases. If the TV is beyond repair, you can also look into recycling options to properly dispose of it.
Ultimately, the best option for you will depend on the extent of the damage, your budget, and your willingness to invest time and effort into repairing or selling the TV.
2/4/2024 5:20:05 PM •
Samsung...
Answered
on Feb 04, 2024
