20 Most Recent
Samsung HT-C6600 Theater System Questions & Answers
I have a HT-C6600 samsung home theatre and while I
If you have it running off of a wireless connection, try plugging it in with an ethernet cable. Also to improve connection make sure no one else using your internet connection is using it while you are watching netflix.
Can not play music from
I have had problem with the unit freezing up. To resolve this, I remove the ipod from the dock
be sure a song is playing on the ipod; replace it into the dock; when the message - no disk - appears, then press the red "A" button to select ipod. That brings up song list and hitting the center SELECT botton on the remote, it plays the song correctly.
HOWEVER, if I hit the return button in the middle of play, I cannot go back and play a different song. The unit freezes on STOP. Or if I wait until the end and go back to the song list, then it starts to play the next song with no sound. When this happens the display on the unit flashes "MUSIC" / (play time), repeatedly.
The Samsung help-line thinks this is a problem with the iPod dock and are sending me a new dock. But I don't think that is where the problem is. I think the HT-C6600 is defective.
Hi, I'm using the Samsung HT-E330K. It works but does not speak out. The power display is fine but no sound
If your Samsung HT-E330K home theater system is not producing any sound even though the power display seems to be working fine, there are several potential causes and troubleshooting steps you can try:
1. **Check Volume Levels:** Make sure the volume on the home theater system and the connected TV (if applicable) is turned up and not muted.
2. **Check Audio Source:** Verify that the correct audio source is selected on the home theater system. If you're using multiple input sources (DVD, TV, AUX, etc.), make sure the right input source is selected.
3. **Audio Cables:** Ensure that all audio cables are securely connected to both the home theater system and the audio source (TV, DVD player, etc.). Sometimes, loose or faulty cables can result in no sound.
4. **Speaker Connections:** Check that all speakers are properly connected to the home theater system and that the speaker wires are securely inserted into the appropriate terminals.
5. **Audio Settings:** Go through the audio settings on both the home theater system and the connected TV (if applicable). Ensure that the correct audio output settings are configured.
6. **Mute Function:** Double-check that the mute function on the remote control or the home theater system itself is not engaged.
7. **Speaker Balance:** Check the speaker balance settings to ensure that sound is not unintentionally directed to one side or speaker.
8. **Reset to Default Settings:** If you've made any changes to the settings recently, consider performing a factory reset to revert to the default settings.
9. **Firmware Update:** If there is a firmware update available for your home theater system, consider updating the firmware as it might resolve any software-related issues.
10. **Test with Different Source:** Test the home theater system with different audio sources to rule out issues with a particular device.
11. **Test Speakers:** If possible, disconnect each speaker one at a time and test the audio to identify if a particular speaker or speaker wire is causing the issue.
12. **Check Speaker Impedance:** Ensure that the speakers' impedance matches the specifications of the home theater system. Mismatched impedance can affect sound quality.
13. **Contact Support:** If you've tried these steps and still have no sound, consider contacting Samsung customer support or seeking assistance from a professional technician for further troubleshooting and repair.
Remember to refer to your device's user manual for specific instructions related to your model.
