20 Most Recent Moultrie D-50 Digital Camera Questions & Answers
The solution to this is by talking it to a tech shop or a friend or family who can tell u how to work the digital camera
Moultrie D-50... | Answered on Sep 21, 2013
Check that you are not in a manual mode. Set it to "auto" as a test. If it just won't flash, then check your battery power. Other than that, the flash could be defective.
Moultrie D-50... | Answered on Nov 08, 2012
You may download a copy of the manual here.
Moultrie D-50... | Answered on Oct 10, 2012
Follow the instructions on page 4 of the manual.
Moultrie D-50... | Answered on Sep 01, 2012
They are close to the D40s inside but the D50 won't fit a D40s "lunchbox"outer case without modifying it. Both are known for flash problems,which usually ends up being bad charge capacitors (3x 250mfd)..
the ones I can't fix,I rob the LCD menu displays,which rarely fail in D40/D50s, and use them in the I40/I60s notorious for bad menu displays...they are interchangeable with minor mods if any.
Oh, you just asked if I worked on them...
Moultrie D-50... | Answered on Dec 19, 2011
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Moultrie D-50... | Answered on Sep 18, 2011
According to the manual, the D-50 accepts SDHC cards up to 16GB in size.
Moultrie D-50... | Answered on Sep 09, 2011
http://images.ebsco.com/pob/Moultrie/catalog/D-50IR%20User%20Instructions-ENGLISH.pdf
Moultrie D-50... | Answered on Aug 19, 2011
http://images.ebsco.com/pob/Moultrie/catalog/Game-Camera-D50-User-Instructions.pdf
Moultrie D-50... | Answered on Aug 10, 2011
You can download the manual from the manufacturer's web site at
Moultrie D-50... | Answered on Aug 07, 2011
My guess is that if you don't even know how to get into the camera, you don't know how to fix it once you get there.
Moultrie D-50... | Answered on Aug 04, 2011
Moultrie D-50... | Answered on Jul 01, 2011
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Moultrie D-50... | Answered on Mar 21, 2011
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Moultrie D-50... | Answered on Mar 12, 2011
Hi Mike no need any driver. there is 2 way. 1. connect the camera with PC via data cable and select the camera data transfer option as USB. Then go in my computer and from there you can find the camera driver and open it and select all the photo and copy them. Now paste on your PC.
2. Remove the memory card from the PC then connect it in card reader . Now connect the card reader in PC & Then go in my computer and from there you can find the camera driver and open it and select all the photo and copy them. Now paste on your PC.
Thanks.
Moultrie D-50... | Answered on Jan 11, 2011
Moultrie D-50 Digital Camera Logo
Popular Tags
31 questions posted
Top Moultrie Cameras Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Zhareese
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
View Most Popular
Moultrie Cameras
  • Moultrie Cameras
Most Popular Question
camera will not flash night
  • Cameras
