20 Most Recent Lenovo IdeaPad Z560(0914-3NU) NoteBook Intel Core i3 370M(2.40GHz) 15.6 Wide XGA 4GB Memory DDR3 10... Questions & Answers
Install a fresh Windows.
Lenovo IdeaPad... | Answered on Aug 29, 2014
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Lenovo IdeaPad... | Answered on Oct 06, 2012
The MAC address is the address that is assigned to the LAN and/or wireless cards in your laptop.
These are permanent addresses and you need to access your laptop to get these addresses.
Lenovo cannot give you these addresses with your serial number, they do not keep a record of MAC addresses.
Lenovo IdeaPad... | Answered on Apr 11, 2011
Hi there Sadi,
I have used this type of laptop before, the product ID is located under the batter of the laptop.
To find it you must remove the laptop battery and look at the sticker that has the ID # on it.
Lenovo IdeaPad... | Answered on Mar 14, 2011
Make sure you download the latest version of the driver on the website of lenovo. Click here to download. Make sure to select the Family and the model of your unit then select the operating system. After you install the driver press FN + ESC on your keyboard to enable the webcam
Thanks for using Fixya.
Lenovo IdeaPad... | Answered on Jan 26, 2011
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
Check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppydrives.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Lenovo IdeaPad... | Answered on Jan 19, 2011
Welcome to Fixya
Your webcam is automatically turned on when you restart the computer. If you want to test if it is working. You can go to this website.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo IdeaPad... | Answered on Dec 03, 2010
If you bought the Lenovo at a local dealer, take it back to them. If you bought it through an online dealer, I recommend you track down Lenovo customer support.
Lenovo IdeaPad... | Answered on Sep 05, 2019
really why not ask the game maker directly for help with your w10.
here they are right>?
https://www.mygames.com/
so what do THEY say , it is there code, running.
does Tetris fail or just your games, unnamed,
this maker is bad company they take over your PC
why run this crappp? it takes over your browser,
and more, and is bad.
the do not even have minimum system requirement there.
nor support. avoid like the Plague.
Lenovo IdeaPad... | Answered on Jun 30, 2019
Restart your computer & start tapping f/8 immediately and keep tapping until black screen comes up. Use the arrow keys to select safe mode the press enter. It will start up in safe mode in each corner, the icons are all out of shape and a help window will open. Close that window. Then go to: Start, Accessories, System Tools, right click System Restore & send to desk top.(The reason to do that will be to use it easier ANYTIME you have a problem.) Then do a system restore back to a time before you had the problem. That should resolve it. If not you will have to do a Recovery after saving everything you want to keep on a Flash Drive. On start, type recovery & go there & follow directions.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Lenovo IdeaPad... | Answered on Apr 16, 2019
It's a mechanical problem with the wiring and contacts along the edge of the screen. No "fix" except screen replacement.
Lenovo IdeaPad... | Answered on Apr 01, 2019
Sarthak Sharma and Carla Bunis want more answers
there are many ways to EJECT
1: the botton on the try , is marked EJECT
do so>>
2: the tiny hole on front of same tray use unbent paper clip, stuffed in hole and try ejects manually.even drive chassis in hand. by self.
3: windows is this ,not stated,but windows explorer
right click the DRIVE D:>? and click REJECT.
4: in windows, make sure the device manager does not list, the DVD as dead,red/yellow or unknown.
if device manager shows the drive missing or bad you need to get the new driver for it.
so right click the drive (be online) and click update drive.
no full model number stated, 330 is not full. number. so says Lenovo.
btw even a empty tray will eject.
if the disk is cracked or label fell , then only way
2 might work and cleaning the jam by HAND.
if way 2 fails.
only total dismantling the DVD drive can fix it.
true jams are hard work. ok?> physical world deal there.
not one poster here said, the button is dead.
saving this post from going to ALL wAYS it can fail and long.
Lenovo IdeaPad... | Answered on Feb 03, 2019
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Lenovo IdeaPad... | Answered on Jan 23, 2019
Lenovo ideapad 330S
330S-nnnnnn what is the sub number on model.
nnnnnn is 11 to 17 and up to 3 latters at the end.
4 years old max 2015 made.
answering for dead screen, no text, no lenovo logo icon on screen.
no prompts, and BIOS hot keys are dead. ok?
remove AC pack and all usb devices
push power button for 10 to 30 seconds and release
this is Forced cold power restart,
NOW is this a cure to the problem?> with power pack put back in? plugged end to end, AC wall to PC.
OK no is not:
remove AC power pack. unplug it)
next is the more hard, remove PC covers 10 screws. page 34
and unplug the battery connector.
as seen on page 36 of your service manual below.
then plug in the AC Power pack now.
does the PC run ok with no 4 year old battery inside?
end no battery test,what was the results now?
moving the battery inside any PC does not make it last longer, only harder to remove and service.
the price we pay for Light and thin.
"higher cost of ownership"
see page 36
https://download.lenovo.com/consumer/mobiles_pub/ideapad_300s-11ibr_hmm_201509.pdf
you asked I told.
Lenovo IdeaPad... | Answered on Jan 19, 2019
Try getting the latest version of iTunes, or reinstall your current version.
Lenovo IdeaPad... | Answered on Nov 13, 2017
You will need a separate recovery disk. Sounds like the recovery partition of your HDD got overwritten. Maybe you can create a windows WinPE (microsoft docs) and use that. This says what to do once you have a recovery disk.
https://pureinfotech.com/how-to-uninstall-windows-8-developer-preview-and-restore-windows-7-step-by-step/
Lenovo IdeaPad... | Answered on Sep 25, 2017
First of all, you need the present password. Then straight after turning the computer on you press F12 or insert multiple times after each other. That way you will stop the normal boot and enter the BIOS settings. There you most likely will be prompted for the password and then under security you can disable or change it.
Lenovo IdeaPad... | Answered on Jun 26, 2017
Each computer on your network should have network discovery turned on. They should also be a part of the same group or network. The default in Windows is WORK, but you can change the name to whatever you would prefer.
How to Turn on Network Discovery in Windows 7
I’m happy to help further over the phone at https://www.6ya.com/expert/james_d4449ffdf318a2c3
Lenovo IdeaPad... | Answered on Jul 18, 2016
Lenovo IdeaPad Z560(0914-3NU) NoteBook Intel Core i3 370M(2.40GHz) 15.6 Wide XGA 4GB Memory DDR3 10... Logo
8 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lost lenovo laptop yesterday complaint
  • Computers & Internet
