20 Most Recent
Soltek SL-86SPE2 Motherboard Questions & Answers
Soltek SL 86SPE L board
http://www.hardocp.com/article.html?art=NDkyLCwsaGVudGh1c2lhc3Q=
That's the best i could find.
My computer won't start?!
well if ytou were already using ur PC then may be the last time ur PC was improperly shutdown. this can cause many mail functions.
now 1st thing to do is remove all the hardware and just leave the Processor, Memory & Graphic card if Any. then start the PC if its power on then Motherboard is OK if wont then Dis Assemble all The parts and then assemble again and try as mention above if it still wont work then may b ur chipset of the board friedd out that you cant visually say its fried.
SL-86SPE-L Motherboard
This took ages to find... and EVEN LONGER to download, it felt like I was on pre-pre-pre-pre-56kbps era.
Anyway, without further ado:
Soltek SL-86SPE/SL-86SPE-L BIOS AM1.5L. Included:
- Flashing App
- How to
- ROM file
86SPE-L15.zip
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Pc wont stay on
check your power supply,earhing problem .proper voltafe .
clean your ram,processor and its position.
check that your bord dont touch the cabinet.
other wise i think your bords register or diode transistor are corrupt.
repair your motherbord chipset if above try are not succes
Sandrew
Dear Flyman1957,
You can download the drivers from this URL :
http://www.downloadtube.com/Drivers/Bios/Soltek-16/
Cheerup and enjoy
One Beep after Checking NVRAM...Update OK
The Computer generates 1 beep. to state that the computer has set itself up properly, without errors. Depending on the bios manufacturer. i.e Pheonix or AMI et,c.
As long as your system is running fine with no crashes or errors.
Then this seems perfectly normal.
Sl-86spe-l
I doubt there's anything you can do actually, short of finding an identical "condensator" [you meant capacitor, right?], and then soldering it onto the old one's contacts. Still, this is a doubtful "solution".
Finding a new Socket478-based Motherboard these days would be a fool's errand as well: they are nowhere to be found... Buying a new one - on the remote chance you managed to find one - is a questionable investment.
I suggest you look for used one's, in your local version of "craig's list" [newspaper or website with people selling used or new stuff] or Ebay.
