20 Most Recent Genica 2.5 USB 2.0/eSATA Aluminum External SATA HDD Enclosure (Black) - Supports up to 500GB (HE2521B) Serial ATA, USB 2.0, eSATA External Drive Case Questions & Answers
Replace the cable you are currently using with your printer cable and see if it is the cable if that is not the case I would open the case, and check your connections on the hard drive, there is a chance it might have come loose.
Genica 2.5 USB... | Answered on Dec 30, 2014
I prefer to use my IDE hard drives as either slaves or masters. If you have another drive on the same cable, one needs to be master, the other should be slave. This applies to CD or DVD units on the same cable, too. On the same end of the hard drive as the plug, there will be a small removable plug. On the paper on the hard drive, or maybe stamped on the circuit board, will be M for master and S for slave. Move the jumper as indicated so you have one of each, and be sure you have the IDE and the power plug firmly connected.Usually the IDE plug farthest away from the motherboard end is for the master. It should be marked master and slave, although it may be 0 and 1 or 1 and 2. Once you have this done correctly, if the mother board still does not see it, you will need to go into the bios setup and tell the board you have an IDE drive. This varies wildly from one manufacturer to the next how to do it, be sure to make only one change at a time to the BIOS, and write it down. If what you did does not make the drive show up, put the BIOS back the way it was and try another setting. Write it down. Your motherboard supports SATA, so if this an additional drive for storage or backup, - if your CD or DVD is SATA, the new hard drive should be a master.
Genica Computers... | Answered on Dec 23, 2017
sometimes its on the label, or by the pins themselves
Genica Computers... | Answered on Sep 24, 2012
Calculus indeed is very conceptual and easy to learn. If you are finding it difficult to learn then you could also use thise online calculators
Integral Calculator
Computers &... | Answered 1 hour ago
3014-6065-6678-9416-8990-1862-4895
Computers &... | Answered 10 hours ago
For a details on how to create a WEB site go to this WEB site.
http://websitesetupguide.com/?gclid=CIr39PrP7qkCFcgCHAod3VYQXA
Promotional products are usually created and distributed to companies to promote their business, their products and/or services. Can also be used to help in fundraising for charity, cancer research funding, campaigns against drinking and driving. The range of products can be a pen with a logo, a hat with a specific crest, any "gadgets" putting a company's products in evidence.
Computers &... | Answered 11 hours ago
to setup the Amazon Echo you need its Amazon echo app from the google playstore app normally the echo will tell you how to do so on its own if it is your first time setting the device up
Computers &... | Answered 12 hours ago
CX series
www.sokkia.com.tw/download/??/CX_series_E-copy.pdf
Jan 1, 2012 - CX-105. CX-107. Compact X-ellence Station. CLASS 2 Laser Product ... Except where stated, "CX" means CX-101/102/103/105/107. • The CX ..... Ignoring this indication and making an operation error .... Make sure that moisture or dust particles do not come in contact with the inside .... detergent solution.
No thanks, this website is perfectly broken due to all the advertising scripts as it is.
The site is nothing more than an advertising tool and it runs itself with no supervision. It is now owned by a capital funding corporation.
Computers &... | Answered 18 hours ago
Please don't post followups as new posts. It doesn't work. Edit or add to the posts you have made.
https://www.fixya.com/users/rehan-35682
Computers &... | Answered 22 hours ago
no it dont have any collective nouns
Computers &... | Answered 23 hours ago
Virtual numbers can be important for maintaining privacy, reducing costs, and improving communication, making the process seamless. The internet-based number can be assigned to any device, whether it's a desk phone or a softphone app on your computer. I read a cool article here: https://callgear.com/blog/virtual-numbers-how-are-they-useful/ . Read it, maybe it will help you get answers to questions.
Computers &... | Answered Yesterday
https://www.goldenwebdesign.org
huh
can you do English?
ask a question and tell what it is first. not just funny codes
Hi
are you saying that you could view them up until now
if so you could try a system restore back to when it was ok
usually found in start programs accessories system tools then system restore
or
start
search or run
type in system restore
then look for a date back to when all was well
windows will then shut down and try to restore back to when you asked it too
and on restart it will tell you if it succeeded or not
good luck
Genica 2.5 USB 2.0/eSATA Aluminum External SATA HDD Enclosure (Black) - Supports up to 500GB (HE2521B) Serial ATA, USB 2.0, eSATA External Drive Case Logo
1 questions posted
Top Genica Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Genica Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Genica Computers & Internet
Most Popular Question
500gb hardrive bought few months
  • Computers & Internet
