20 Most Recent
Soltek SL-915G Pro-FGR Motherboard Questions & Answers
Drivea
Hello
If you want to download drivers and software for HP Compaq NX6120,
then you can download then from the
support pageBest regards,
Zizzler
Drivers
Should use all stock intel drivers for major components. NOt sure for gige and audio
Chipset: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=816&DwnldID=13499
Video: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=N&ProductID=2876&DwnldID=14386&strOSs=44&OSFullName=Windows*%20XP%20Professional&lang=eng
Motherboard
use averest home edition, free version
find drivers at chipset of supplier worked OK
Soltek SL-B5A-FGR M/board drivers
Get a friend to download (PCwizard) and install to your computer then run it
It will list all drivers needed for your computer.
Note name and number of them then get friend to do a search for them and download them for you
Check System Device drivers and any with a tellow mark on them need installing
Bios update
go to site dl it run it should auto do itself or install on floppy ok then boot into flooppy 1st tell bios floppy 1st ok or cd ect ok
USB port is not working under windows xp sp 2
hi,
you can try the following steps.
Install the driver for the camera and the ipod as XP is preloaded with drivers for cameras for only selected models only.
Hope it helps.
Regards.
bzoy
Won't run POST
mobo battery is batery in video card try pci differt video 1 pice ram or the other power grounded well with all screws
No signal in monitor
check the powersupply unit. if the unit does not take load there is no display. the psu will on but does not have the capacity to boost the power to the mother board. please check changing it
