20 Most Recent Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5" Internal SATA II Hard Drive Questions & Answers
Toshiba hdd
As far as I know it is not possible to remove a password from a hard disk. In some cases a manufacturer may be able to help, however, for security reasons I'm not sure they would.
3/19/2014 10:51:39 AM • Toshiba 320GB... • Answered on Mar 19, 2014
0answers
3answers
Whenever i plug my toshiba
Don't be panic. you can try some data recovery software. You can seehttp://www.asoftech.com/adr/It tells the steps how to perform data recovery.If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
11/14/2012 4:03:39 AM • Toshiba 320GB... • Answered on Nov 14, 2012
When I start my computer, there is a mes
backup asap and replace the drive
11/7/2012 8:47:10 PM • Toshiba 320GB... • Answered on Nov 07, 2012
Seagage 340g is not comming up on my laptop
It's gone. The drive has croaked.
6/9/2012 3:24:18 PM • Toshiba 320GB... • Answered on Jun 09, 2012
0answers
Hard drive has power but will not spin up
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach frrom motherboard to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working hope this helps you
3/22/2012 9:34:17 PM • Toshiba 320GB... • Answered on Mar 22, 2012
I need this controller board for MK3265GSX
Almost any SATA board will do so long as you have a free slot.I notice you state its for a small form drive so my question it...Are you talking about a laptop or regular PC ?Half a question without detail gets you half an answer
12/19/2011 4:32:40 AM • Toshiba 320GB... • Answered on Dec 19, 2011
2answers
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
11/20/2011 8:48:40 PM • Toshiba 320GB... • Answered on Nov 20, 2011
My toshiba external hdd can
you would either format or delete all of the data from this drive if it has an operating system on it you would format it you have to format your hard drive using a third party disc to erase everything on your hard drive During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system note after you have loaded the operating system you should go back and change the first boot device to your hard drive The BIOS is AMI. Under ADVANCED SETUP: The options listed for 1st,2nd ,3rd Boot device include:IDE0 means Pri master IDE1 means Pri slave IDE2 means Sec master IDE3 means Sec slave
or if you are using a USB insert your usb drive click start right click on my computer select open you should see your USB drive right click then select format another way is to control panel administrive tools,computer management disk management right click on your drive select format hope this helps you www.WipeDrive.com
8/24/2011 4:14:53 AM • Toshiba 320GB... • Answered on Aug 24, 2011
My laptop needs the driver
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on ithope this helps you
8/11/2011 5:10:01 AM • Toshiba 320GB... • Answered on Aug 11, 2011
My hdd not detected.it working
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work but if it is
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also check the Cmos battery and computer ram make sure they are securely seated another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system information all of your computers information will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
8/3/2011 7:49:37 PM • Toshiba 320GB... • Answered on Aug 03, 2011
My laptop do not detect
Ensure that the hard disk is a working one and properly fix into your DELL laptop.
Best regards.
7/18/2011 11:29:04 AM • Toshiba 320GB... • Answered on Jul 18, 2011
Hi my toshiba mk3265gsx hard
With a brand new drive, you have to initiate your drive using the Disk Management tool in Windows.
To do this, go to Start-->Control Panel --> Administrative Tools --> Computer Management. Then select Disk Management from the menu on the left. Once everything is loaded up, you should see your new drive in the list of volumes on your computer. You'll have to right click on it and click Initialize Disk. Once you've initialized it, you'll have to formate the drive and create partitions.
If you need anymore help, let me know.
7/17/2011 11:00:28 AM • Toshiba 320GB... • Answered on Jul 17, 2011
Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5" Internal SATA II Hard Drive Logo
43 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Mk Toshiba
  • Mk Toshiba
Most Popular Question
whenever plug toshiba
  • Computers & Internet
