20 Most Recent Maxell 665203 USB 2.0 Hard Drive Questions & Answers
When i plug in the usb i cant find on the computer
if your computer came with a motherboard disc the drivers could be on it click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
5/29/2011 12:44:31 AM • Maxell 665203... • Answered on May 29, 2011
2answers
When i am connectind my
Try connecting it to another computer and if it also slows down, something is probably wrong with your external hard drive and you should get a new one.
3/1/2011 5:11:55 AM • Maxell 665203... • Answered on Mar 01, 2011
How do I install my new Maxell USB 2.0 flash drive, 32 gb? it's plugged into the USB slot, and the icon shows on the desktop as Untitled. What do I do to get it working?
It should be ready to use. You can name it. Perhaps you need to "format" the drive. Right-click the drive icon, and select "format"
6/15/2018 3:05:08 AM • Maxell Computers... • Answered on Jun 15, 2018
My usb flash drive can't work
Buy a new one on Amazon. They are not expensive and are essentially throw away items.
7/4/2017 2:00:28 AM • Maxell Computers... • Answered on Jul 04, 2017
I bought the maxell usb 360 4gb. How do I use the password part of it? I plug it in and it is just like a regular usb with no password protection.
You must input password protection, if you don't want it then don't set up any password.
2/8/2017 7:02:42 PM • Maxell Computers... • Answered on Feb 08, 2017
I BOT IT NEW AND I TUCHT SOMTHING NOW I GOT NO SPACE
Your question can't be answered due to it being too vauge and bad spelling.....
3/16/2014 1:56:01 AM • Maxell Computers... • Answered on Mar 16, 2014
8GB Flash Drive showing only 499MB of memory. How
Delete its partition / partitions using windows disk manager and recreate partition.
10/15/2013 5:24:13 PM • Maxell Computers... • Answered on Oct 15, 2013
Maxell myGEN MY-500 Plugged in, blue light on, not
No hard drive in the last 30 years needed drivers installed except for a short time when SATA hard drives first hit the market with Windows2000 and XP. I believe that is an external drive usually used for backups. You did not post your operating system, and if this is a new drive or one you have had for some time. So I will use Windows7 and assume this is a new purchase:>Try a different cable and a different USB port in case the cable or port went bad. It happens.>Plug the drive into a different computer. Is it recognized?>Go into Device Manager; is it listed?>Enter Control Panel/System & Security/Administrative Tools/Create & Format Hard Disk Partitions. Is your drive shown there? If it is, Right click on it, then click Mark Partition as Active. Does your computer see it now?If the answer is no to all the above, the drive probably failed.
10/8/2013 12:44:56 PM • Maxell Computers... • Answered on Oct 08, 2013
Flashing blue light
it proberly read or writes
7/30/2013 7:20:48 AM • Maxell Computers... • Answered on Jul 30, 2013
Maxell max data 1tb hard drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
if you can see your usb drive but its not working ports (com&lpt) right click update driver click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive click start all programs accessories open windows explorer navigate to your data right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in or if you are downloading data from the internet once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb deviceif you need more help with this post a reply hope this helps you
11/15/2012 5:50:34 AM • Maxell Computers... • Answered on Nov 15, 2012
My 32 gb flashdrive says that it needs to be formated but will not let me because it is write protected, so can someone tell me how i can format it so i can use it again
click start click to open on my computer you should see your Usb drive E: or something
right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions
make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select openRight click the icon of your Usb Drive (It should be E:/ or something) Click Properties in the menu that comes up Click the Sharing tab Click permissions And finally, click Allow next to Full Control. click start click on my computer to open you should see your drive right click then select format another way click start control panel administration tools computer management disk management right right click on your usb drive select format if you need more help with this post a reply hope this helps
10/31/2012 10:41:59 PM • Maxell Computers... • Answered on Oct 31, 2012
I can't open the CD
make sure that all leads that attach to your cd: drive are secure and are not faulty
8/22/2010 8:48:16 PM • Maxell Computers... • Answered on Aug 22, 2010
6answers
Cd rom won't recognize disk
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
7/27/2008 11:10:22 AM • Maxell Computers... • Answered on Jul 27, 2008
Maxell  665203 USB 2.0 Hard Drive Logo
2 questions posted
Top Maxell Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxell Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Maxell Computers & Internet
Most Popular Question
when am connectind
  • Computers & Internet
