20 Most Recent Haier HL24XLE2 LCD TV Questions & Answers
TV turns on, but no display at all just white screen.
T con pcb might be faulty or the screen.
1/10/2014 4:28:15 PM • Haier HL24XLE2... • Answered on Jan 10, 2014
Have blank white screen when powered on, why is this happening?
Check its back-light inverter board. Replace it if found faulty. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
1/9/2014 10:58:20 AM • Haier HL24XLE2... • Answered on Jan 09, 2014
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
9/16/2012 3:18:10 AM • Haier HL24XLE2... • Answered on Sep 16, 2012
Haier tv flashing green and red and wont come on
Try changing the input device to something you are sure, works such as a DVD player.Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
8/2/2012 9:53:10 AM • Haier HL24XLE2... • Answered on Aug 02, 2012
Haier tv flashing green and red and does not come on
May be you have a faulty video cable from your cable set-top box or your DVD player--try changing the cable to see if it fixes the problem.Also, is the video cable an HDMI cable or component (like RGB)? If it is a component cable, it may be they are connecting properly.
8/1/2012 4:44:00 PM • Haier HL24XLE2... • Answered on Aug 01, 2012
The orange light is on all the time on the front of the tv but tv will not come on
Good day!!!!That problem is usually cause of faulty capacitors on the power supply board..Just follow this instruction to fix your TV..1. Open the back cover of your TV.2. Look at the power supply board..Its normally connected to the power cord..3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..5. Some of the capacitors not bulged so its better if have a capacitance meter
6/6/2012 1:33:08 PM • Haier HL24XLE2... • Answered on Jun 06, 2012
Can not get video from
Try setting the TV from Component (YPbPr) to VGA (RGB).
11/23/2011 1:25:14 AM • Haier HL24XLE2... • Answered on Nov 23, 2011
Tv screen delays causing double/tripple
Informed customer to try emailing Haier for product support since she can not call the toll free number, also suggested that she unplug the television for about 5 minutes to allow the set to rest itself. Then plug the set back in and try turning on to see if this cleared the symptoms..
8/3/2011 3:49:02 AM • Haier HL24XLE2... • Answered on Aug 03, 2011
2answers
My sound no longer works.
Tries tv and those pay boxes unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.For those pay boxes to reboot and upgraded it softwares.Go into the tv menu go to Sound Setting go down do a resetting itself back to factory setting.By doing these steps tv have a great chance to get it audio back.If tv still have audio problems,than the main tv Tuner signal board have problems.Tv is under a year old.Call the Haier tv Corp.Take ur tv warrenty repair.
7/7/2011 5:05:49 PM • Haier HL24XLE2... • Answered on Jul 07, 2011
How do i hook surround sound to my Haier TV L26B1120a
Are you using a cable or satellite box? If so you can connect the audio out jacks to the Surround Sound instead of the TV.
6/3/2018 5:48:48 PM • Haier HL... • Answered on Jun 03, 2018
I lost my tv remote of motel 21f17ss.can i get the
you have to go to your dealer to order a new one//
9/11/2013 12:44:16 PM • Haier HL... • Answered on Sep 11, 2013
HLH19W how can I Access a channel on my tv with
no no no no you cant..
9/10/2013 1:39:03 PM • Haier HL... • Answered on Sep 10, 2013
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM • Haier HL... • Answered on Oct 26, 2012
0answers
My Haier tv model LE55B1381 has an intermittent problem. It stops working i.e. power is ON but no sound or images. After an hour, it resumes working for a day then stops again.
Hi, please remove all accessories from your tv and monitor it to see if it runs into it's glitches again. Please also remember if you purchase a new remote when this issue started happening or did you start using direct tv ? You can also run a power cycle on the tv if this issue occurs again. Thank you.
11/23/2022 3:13:04 AM • Haier Televison... • Answered on Nov 23, 2022
2answers
How can I rotate the screen of my haier tv model LE32B7000
You should enter its service mode menu to do that. Visit these sites by a desktop computer and type in the model number of your set at the search window at the right side of the site to reach it very fast. Mobile view have no search box. https://electronicshelponline.blogspot.com/ https://elektrotricks.blogspot.com/ https://electrohelponline.blogspot.com/
9/26/2022 5:05:59 PM • Haier Televison... • Answered on Sep 26, 2022
Haier HL24XLE2 LCD TV Logo
18 questions posted
Top Haier Televison & Video Experts
Jaime Hernandez
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
HL Haier
  • HL Haier
Most Popular Question
not get video from
  • Televison & Video
