20 Most Recent
LaCie Rikiki Go Hi-Speed USB 2.0 500GB (Silver) - 301939 - 2,5 external Hard Drive Questions & Answers
Recgonition
Blank drive. Reformat it and see if you can save anything to it.
I need to know how to do a factory reset on a lacie 4Big Quadra enterprise.
- Disconnect all cables from the device.
- Press and hold the "reset" button (located on the rear panel) for about 10 seconds.
- Wait for the device to restart and initialize. This may take several minutes.
- Reconnect the cables to the device and try accessing it again.
Note: It's recommended to backup all data stored on the device before performing a factory reset, as all data will be lost during the reset process.
My LaCie external drive isn't getting power
U should test for power at the connector that goes into the lacie with a voltmeter to make sure power supply and its wire are OK. If no voltmeter then use a automobile brake or turn signal bulb to see if it has power.
