20 Most Recent Gateway FX6803-35 (PTGBD02004) PC Desktop Questions & Answers
My loading is real slow most programs don't even load
What program and where did you download it from?Sounds like a virus to me. Run some scanners such as Malware Bytes
1/29/2013 7:17:49 AM • Gateway... • Answered on Jan 29, 2013
I keep getting a message that the battery needs to be replaced. Where is it?
It is on the motherboard. Take the power cord off the unit and panel to access it. On the board is a small round battery which is about half an inch in diameter and silver (chrome plated) somewhere on the board. Usually a CR 2032. It is what powers the memory of the CPU. Cost is around $2.50
9/28/2012 6:24:55 AM • Gateway... • Answered on Sep 28, 2012
Downloads are difficult to perfirorm.
IE is corrupted- the download program from it is gone. The only way to fix that is to reinstall Windows. It's simpler just to use another browser - Opera has a fully operational download manager in it.
1/23/2011 10:55:45 PM • Gateway... • Answered on Jan 23, 2011
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
3/21/2017 7:48:25 AM • Gateway Fx... • Answered on Mar 21, 2017
How do I manually ejecting a disc from a gateway
press the button on the disc drawer and it opens
7/29/2014 12:14:43 AM • Gateway Fx... • Answered on Jul 29, 2014
How do Imanually ejecting a disc from a gateway
There should be a small round hole on the door near the eject button. Using a straightened heavy paper-clip, insert straight into the hole. There is a lever inside that you will feel, press in until the door comes partly open. Then you can pull the door to access the disk.
7/28/2014 7:51:07 PM • Gateway Fx... • Answered on Jul 28, 2014
Manually ejecting a disc from a gateway
If there is a little pinhole by the eject button, unroll a paper clip and stick one end in it.
7/23/2014 10:23:01 PM • Gateway Fx... • Answered on Jul 23, 2014
Restore gateway FX to factory settings
If your restore partition is intact, you can press F11 at boot, and follow the on-screen instructions to do a factory restore. Be sure to backup your data first, as it will be deleted in a Factory Restore.
7/16/2014 7:51:08 PM • Gateway Fx... • Answered on Jul 16, 2014
Cd driver not opening
Open a paper clip and see if you can find a tiny hole in the front of the cd drive. Push the sraightened out paper clip into the hole and the drive should open without power on the computer. The hole on my dvd plyer is just above the switch which opens and closes the dvd drive. If the paper clip is too big you may have to go to a pc shop and buy a pin which comes with most new dvd players. If the owner of the shop is a nice person they may give you a pin and explain more.
1/18/2013 7:44:44 AM • Gateway Fx... • Answered on Jan 18, 2013
How to removed a virus of the computer
Use your UP-TO-DATE AntiVirus and run a FULL SCAN. ALSO Download, install, RUN a FULL SCAN with MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ , UNCHECK the PRO TRIAL, you want the freeware version. If you cannot download , reboot to safe-mode with networking and download Malwarebytes and run your AntiVirus. Respond to post for furthwe assistance.
12/3/2012 5:37:43 PM • Gateway Fx... • Answered on Dec 03, 2012
Searching for FX6801*03
What is fx6801-03?
6/3/2012 2:22:14 PM • Gateway Fx... • Answered on Jun 03, 2012
Windows error 8000_4002
What were you doing when you got this error?
4/27/2012 7:23:17 AM • Gateway Fx... • Answered on Apr 27, 2012
Windows error code 8000-4002
What were you doing to get this error? When is this happening?
4/27/2012 7:22:34 AM • Gateway Fx... • Answered on Apr 27, 2012
Power suppy connections to computer
What is the question? When hooking up a power supply, there are only 2 plugs to hook up and there are only 2 places on the motherboard where they fit.
3/22/2012 4:55:20 PM • Gateway Fx... • Answered on Mar 22, 2012
My gateway lt2016u crashed
Crashed How? What happened and what's it doing now?
3/19/2012 1:28:35 AM • Gateway Fx... • Answered on Mar 19, 2012
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do. First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button. Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button. Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation. I hope this helps!
3/14/2023 5:41:18 PM • Gateway... • Answered on Mar 14, 2023
Gateway FX6803-35 (PTGBD02004) PC Desktop Logo
Popular Tags
3 questions posted
Top Gateway Computers & Internet Experts
Steve Nordquist
Steve Nordquist
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Fx Gateway
  • Fx Gateway
Most Popular Question
downloads difficult perfirorm
  • Computers & Internet
