20 Most Recent
Apple iPod Nano 6th Generation MP3 Player Questions & Answers
How to sync music
Make sure that you have downloaded iTunes. Then load your media into iTunes. You the want to connect your iPod to your pc or Mac. It will show up on the side bar click on that and you can adjust your sync settings the on the lower left side click on the button that says apply. This will put your media on your player. Hope this helps
My ipod 16 gb is disabled for 22406918 minutes & i forgot my password
Hi mythreebratsIf you have forgotten the code, you can unlock the IPod by doing the following:Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.If you want to change the primary computer that your IPod is associated with, do this:1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.2. Connect your iPod to the computer that you want to be the primary computer.3. Open iTunes and synchronize.If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.Please take time to rate me Bud
Water damage ipod nano
It looks like your Ipod is damaged beyond repair.If it could be repaired it maybe too expensive. I suggest you put your money towards a new Ipod.
I pod nano 6th
font.f1 {font: 12.0px Helvetica}
Thanks for asking your question with Fixya Support. I will be glad to assist you.
You are correct, it is not your car, or the iPod Nano 16G. The issue may be that your iPod Nano may not be compatible with the playback device you are using successfully with your other iPod (especially if it is not a Nano). You did not specify what device brand you are using for your car's USB playback audio for your iPod, so I cannot really determine the compatibility and if that is what the issue is.
What I can say however, is that more than likely, even without knowing the device you are using for iPod playback in your car- it has to be an issue with compatibility.
If I could advise anything for you, it would be that you check the car audio built-in connection's specification from your car's owner's manual (or online via the vehicle manufacturer or dealer website) and see if there may be a known connectivity or compatibility issue.
This is only recommendations, however, if you can provide more information regarding the USB connection and the details of your car, hopefully I can go further for you.
Thanks for your inquiry, please let me know if I can answer further questions for you regarding this subject.
Regards,
Mactechtrainer
How to flip screen around
The 6th generation iPod nano doesn't have an accelerometer, but its screen can still be rotated. Here's how.
Begin by putting two fingers at corners of the screen. This can be opposite corners (one finger at the top right corner of the screen and another finger at the bottom left corner, or vice verse) or corners on the same side (top left and bottom left, for instance).
At the same time, twist your fingers in the same direction (clockwise or counter clockwise). The screen should rotate with your fingers. Remove your fingers from the screen when it's oriented the way you want.
If you like my solutions kindly rate it.
Thank you
