20 Most Recent
Uniden UDR444 Video Survailance System; Two Weatherproof Cameras, 4.3" LCD Display, Digital Zoom, 480 x 272 Resolution, 500 Foot Range, Motion Detection, Two-Way Audio, microSD Card & Rechargable Monitor Battery Questions & Answers
ONE CAMERA SAYS OUT OF RANGE
Try to walk closer to your camera with your monitor to see if the video feed appears. If not, you may want to send your unit in for repair.
Power witch goes on an off
Check for a dirty switch. Sometimes bugs or just dust builds up as in mine once. Clean properly an gently. Maybe it will come back to life.
How do I get the cd for uniden udr444
It appears you might be out of luck. The only driver I can find is on the CNET site an its called USB Composite driver. Could work because it is for USB ports. If it dont work your only chance is a call to uniden or ebay.
Need to pair my udr444 cameras to my pc
Most security cameras put out an analog signal....whereas PCs need a digital signal. It may work if you find a program to convert the analog signal to digital. If I were you I would just buy a small flat screen tv and use the Audio/Video input.
Signal issues
If the antenna on the camera can be removed then there are long range antennas available that will increase the signal strength. You have to if the camera is transmitting on 2.4 ghz or 5.8 ghz before you look online for an antenna. just google 2.4 ghz antennas for a list.
I have a Uniden UDR444 Surveillance System and
You need to review if your computers have all options of Flash software or some application directly of the manufacture that you download from web. Also What is your OS of each Computer.
I Brought a Uniden HD8000UPVR digital receiver in
I suggest you read the manual.
If restoring defaults doesn't produce channels the sales guy probably lied, however installing the right software should restore functionality.
The manual lists a website for NZ.
Perhaps Uniden customer service can advise you further.
11/27/2017 4:09:48 AM •
Uniden...
Answered
on Nov 27, 2017
