20 Most Recent
Activision Call of Duty: Black Ops for Nintendo Wii Questions & Answers
Can two players play call
Sign into a PSN account and launch Call of Duty: Black Ops III. After reaching the Main Menu, connect a second controller. Press X on the second controller to connect the other player online. Once connected, press X again to attach the split screen player.
When i try to play
From looking around, it looks like some type of bug. They are working on a patch that will hopefully be released soon.
Here are some instructions I found at
Support Forum.
- From the Multiplayer menu
- Select Profile
- Create a new profile
- Select "Nintendo Wi-Fi Connect" and wait to see if you login
- If you are able to login, select Profile again
- Change back to your original profile
- Select "Nintendo Wi-Fi Connect" again, and you should be able to play on your original profile.
- If you are still not able to login please refer to the rest of the information on this page.
Where can I find a
Visit this link and you can download it in .pdf format
http://www.fileshack.com/file.x/22666/Call+of+Duty:+Black+Ops+Nintendo+Wii+Manual
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
