20 Most Recent
Activision Dj Hero 2 for PlayStation 3 Questions & Answers
When i put the game
This seems like a disc problem. You will need to get another copy. If this isn't the problem nor solution, you will need to replace the laser in your blu ray drive. If that is the case, please post another question for instructions.
I am having a problem.
Direct3D 6? Wow, the game must be way older than your computer. You probably installed DirectX 10 or later. There were major changes after DirectX 9. The software routines to manage graphics hardware acceleration through DirectX 10 or newer are probably very different from DirectX 6, so the game's graphic controller interface can't find them.
Try going into the game properties (right-click on the main executable file and select Properties from the pop-up menu).
Set it to run in XP compatibility mode and see what happens.
Check to see if the game has the option to run without hardware acceleration. If this provides acceptable performance, that is your answer.
If necessary (and if Microsoft still makes it available), try installing DirectX 6. Vista may snag on it and make you remove it and reinstall a newer version, but it's worth a shot if the other fixes don't work.
Yo dudes I play call of duty modern warfare 2 and
This is hard to answer because i dont know your style of play but if you dont care to be called a noob and such i would go with an asuslt rifle such as the tar-21 or scar-h with the grenade launcher and a shotgun as your secondary or akimbo pistols. This combo willget you many kills but you will be yelled at lol
Password of currpted file
Did you set up any password for this game, if not, I suggest call activision 1-310-255-2050 11am to 8 pm PT Monday to friday
