20 Most Recent
Sony - Go for PSP Questions & Answers
How do I correct the PSP error 80023102? Thanks
Here's how I think you can tackle it:
1: If your credit card number is appearing in x's (e.g.. 111xxxxxxxxxxx357) then retype it.
2: If you live in a flat/ apartment then placing your address on 1 or 2 lines might help
3: Is your credit card still valid?
4: Having your billing and residential infomation typed in the same might help.
If none of these helped contact Sony.
I cant play games
ur getting error u dont know how to play
find on google for tutorial
Well i waz installing an
It clearly says on the downloading screen that you must not turn off the PSP, disconnect the AC charger (if connected), or put the PSP in sleep mode. Pretty much leave it alone when you download it. To reset the PSP, you can take out the battery and put it back in and it should work again. Then re-download the update.
My games will not play it reads ''not
The thing is, you got the games from a different PSN account. Sony doesn't allow you to play games from a different PSN account, so I advise you to either delete those games or go onto the PSN account you got those games from. Or if you have the money, buy those games on your account.
No light seen in he
That.s very general.First, we need to know the details why the screen got black. Tell us what happen. Usually screen goes black if the PSP got BRICKED.what is that mean? Bricked- is the word used in PSP terms wherein the unit components were damaged like for a file that is corrupted, your unit can be Semi-bricked. we have tools to unbrick it all you need is a pandora battery and a MMS - magic memory stick
and a Magic memor stick
once you have those, you can go here, http://wololo.net/wagic/2011/05/29/cfw-4-dummies-updated-with-latest-cfwhendowngrader-information/for a CFW- custom firmware on your PSP.always make sure that your PSP has a battery with fukk charge
Battery dead and I can
I first recommend replacing the battery. It is cheapest and easiest.
If problem persists, then you may have a faulty board or capacitor that will have to be found with a cap tester. Double check ribbon cable from battery to board to make sure there is not a loose conneciton or broken wires.
Where is psp go aoss
he aoss is for an easy set up, just turn on your psp, go to infrastructure settings, and scan for your router. then just use the auto everything to set it up.
Unless you have a WEP key then you have to enter that.
But the Aoss Button is not on the PSP its on your router.
