20 Most Recent John Deere Riding Lawn Mower. D140 48 in. 22 HP Front-Engine Questions & Answers
check and see how much fluid in trans mission and change hydrostatic transmission filter
John Deere... | Answered on Aug 16, 2014
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
John Deere... | Answered on Aug 10, 2014
It is belt driven directly off the engine crankshaft.. The belt tension is released when you push in on the brake pedal.
John Deere... | Answered on Sep 15, 2020
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
John Deere... | Answered on Sep 14, 2020
The fan should rotate so that the air is being sucked through the radiator .
John Deere... | Answered on Sep 09, 2020
i suggest you google your owners manual if you dont have one
John Deere... | Answered on Aug 22, 2020
replace the pto solenoid as it has an internal short causing the fuses to blow.
John Deere... | Answered on Aug 14, 2020
ASK JOHNDEERE OR GOOGLE IT
John Deere... | Answered on Aug 08, 2020
You have spark and fuel, that leaves compression and timing.
To test compression remove spark plug, place thumb or finger tightly over spark plug hole and pull starter cord. If your finger is pushed off the hole with pffft sound then likely compression is sufficient.
If no compression then likely a valve is stuck or a valve guide has moved out of place. Was it ran out of oil? If yes the engine rod may have snapped.
Timing will only be wrong if the flywheel key has sheared. To check timing requires a special tool or removal of the cylinder head. It's a simple flat head engine so not a difficult task to remove head and the gasket is reusable. Or just remove flywheel cover and flywheel and do a visual inspection of the key.
John Deere... | Answered on Jul 22, 2020
Safety interlock relay or safety circuit failure.
Try the following test.
Ignition in RUN position
Engine not running.
No operator in seat.
PTO OFF
Brake ON
Press down and release the seat. You should hear the faint click/click sound of the interlock relay as seat switch opens and closes.
If you hear the interlock relay click, try repeating test with brake OFF. Results should be the same.
Comment below for further assistance.
John Deere... | Answered on Jul 17, 2020
I couldn't with any certainty tell you there are no reed valves in the engine of your mower but reed valves tend to be fitted almost exclusively to high performance 2-stroke engines. Compressors have them and it could be argued diaphragm type carburettors have them (with a stretch of imagination).
Most ordinary duty 2-stroke engines use piston controlled ports while virtually all 4-stroke engines made in the last century use poppet valves and I strongly suspect that applies to your mower.
John Deere... | Answered on Jul 08, 2020
worked on alot of John Deere motors at the shop we torque them in 2 increments 15 ft. lbs. , run for 15 min. let cool down. then 30 ft. lbs.
John Deere Riding Lawn Mower. D140 48 in. 22 HP Front-Engine Logo
5 questions posted
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
View Most Popular
John Deere Garden
  • John Deere Garden
Most Popular Question
wont john deere d140 move when engage
  • Garden
