20 Most Recent Edu-Science Edu Science Microscope 600X Questions & Answers
Well I have the instruction manual, but it is not too helpful. When I was a child I put fleas and ants on the slides, but I guess this microscope is different. Here is what my manual says.
How to make a prepared slide: If the given sample is not thin and transparent, it cannot be observed by the microscope as the light from the reflector or the light source does not pass through it. Fibers, pollen, wool, or salt can be observed easily and a cover glass is optional. Clear samples are stained first with a drop or 2 of methylene blue, Eosin or other dying solutions (not included).
1. TEMPORARY MOUNT: Wipe the slide and cover glass clean. Slice a thin sample with the micro-slicer (blade is very sharp...adult supervision). Pick up the sample with tweezers and put it on the center part of the glass slide. Put one drop of water on the sample using the needle that came with your kit.
2.PERMANENT MOUNT:Proceed as above, however, before covering the slide with the cover glass, add a few drops of gum media (not included, available at the store) or Canada balsam solution or transparent adhesive glue with a disecting needle to the slide. Push down on the cover glass with the tweezers to fix it in place and leave to dry for a day.
VIEWING LIVE BRINE SHRIMP:
1.Pour a small amout of brine shrimp eggs into the petri dish.
2.Add enough water so that the eggs are submerged and add just a dash of table salt.
3.Place the petri dish in a well lit area (under a lamp with a 60 watt bulb is good, for 24 hours).
4. When you see movement in the petri dish place it on your microscope stage, turn on the light and watch the brine shrimp in action.
Edu-Science Edu... | Answered on Jan 22, 2011
It used to be you could do all sorts of stuff, like make stinky smells and make loud pops and bangs. These days everyone is so careful that there isn't much you can do. In any case, I use Google to find more details about the particular set you are thinking of.
Top Chemistry Sets or
Science Project Kits Buy Online at Fat Brain Toys
Edu-Science Toys | Answered on Jul 06, 2014
I patiently used Google Translate and got this. The instructions may not be in perfect English, but it's good enough to understand. Good luck :)
GROWING CRYSTALS
1.
experiments require a large measurement cup (at least 32fl oz / 0.9 1) Heat resistant glass mix the powder and boiling water. The vessel measures must be glass or plastic Resistant to heat. You also need a medium saucepan (at least 32 fl oz / 0, 9 1) to boil water. Separate carefully cut molds, as pictured. Make sure to leave a border around each mold. Also remove sharp edges from the edges with scissors.
2.
Use a large glass measure (at least 32 fl oz / 0, 9 1) (not included) to measure 0.68 liters of water and pour into a medium-size saucepan. Heat the pan until the water boils.
3.
Open the bag of potassium sulfate 10 (diamond frosting) with chemical crystal growth and pour the contents into the glass of measures.
4.
Pour boiling water in medium saucepan shot glass with the contents of the bag 10.
5.
Stir the mixture with the big stick until all the grains are completely dissolved chemicals. NOTE: Let the mixture cool for 5 minutes after the grains have dissolved.
6.
placed 2 rocks on the bottom base of the 5-sized plastic molds "C" of growth. These basement rocks should rise only about 3 / 4 "(2cm) from the bottom of mold growth.
7.
Pour the chemical solution / water shot glass molds in size 5 "C" for crystal growth. Make sure to fill each mold in the same way, leave an inch (8mm) of space between the liquid and the edge.
8.
After removing the bottle cap coloring dye, carefully cut with scissors (not included) the tip of the boat. Individual drops slowly drops of dye into the mold of crystal growth. see diagram following Mercedes to mix colors. Once you add the dye mixture solution with the small mixing stick. NOTE: Do not add dye to the mold of a glass. transparent crystals are better for the electronic.
9.
Place the mold of crystal growth in a place where not disturbed by movements or changes in temperature. crystals begin to grow in a matter of hours. let the crystals grow for three or four days without disturbing them. You can then remove the crystals from the solution. For best results, wash the crystals abundantly in the sink to remove excess dye and place on a newspaper or paper towel for a day to dry.
10.
if the mass of rock crystal and the base have been a square shape due to the structure of the mold growth, you can break the remaining crystals that form the block so that the crystalline mass display look more natural from the geological point of view. to expose the glass, LED lights the base by pressing the button on the bottom. transparent glass placed at the base and see how it changes color. if you are not using the base, be sure to extinguish by pressing the button again. to replace the battery, remove the cover with a screwdriver as shown below. NOTE: with the help of a magnifying glass, look closely at the detailed crystal structure of the crystals finalized.
Beak-shaped crystals: follow steps 2-10 with the following changes: In step 2, only 0.34 a boil water. In step 3, use the contents of the bag 11.
In step 6 uses the five molds size "D" of growth of crystals with a single rock in each base.
In step 8 uses color guidelines mold "D" (crystals spike) in the diagram below.
NOTES: replacement of the battery base. Place the base upside down. Now you can remove the battery cover to access it, as shown in the image below.
Edu-Science Toys | Answered on Nov 28, 2011
Welcome to Fixya. i I've seen the website of Edu-Science however they dont have the link to download a manual for the Magnet Deluxe. I've provided the link of the product and the contact info of Edu-Science aswell you can send them an email and ask if they have the copy of the manual.
Edu-Science Magnet Deluxe
Edu-Science Contact Info
If you have questions please let me know. Thanks for using Fixya
Edu-Science Toys | Answered on Mar 14, 2011
Fill the barrel most of the way with stones, add coarse grit, add enough water to just cover the stones and then clean where the lid seals carefully. Seal it up and run it for a week, dump everything into a colander and rinse. Don't run that mud down your drain because it will plug it mightily, run it outside.
Do the same process with the fine grit, run it for another week and rinse and admire.
lp
Edu-Science Toys | Answered on Jan 02, 2011
I used to have exactly that same rock tumbler. I have a bunch of polished rocks out in my garden that the kids and I made with that thing.
I don't have the instructions, but there are some perfectly great generic instructions on the geology.com web site: http://geology.com/rock-tumbler/rock-tumbler-instructions.shtml
I used these directions with great success.
Edu-Science Toys | Answered on Dec 31, 2010
Wow that is a nice one you have, it is probably quieter with the plastic cover. I use to tumble my rocks either in the basement or in an empty drawer in my dresser to sort of block out some of the noise. The one I had when I was younger was probably the first do it yourself old Smithsonian rock tumbler. I'd say that was probably one of the best gifts that I have ever received.
Well, first, you put the bag of rocks that you want to tumble in the tumbler. Make sure it only fills the barrel 2/3-3/4 full or you may have to extend polishing time.
then, usually you use the thickest to the thinnest grit in that order. You put the thickest grit in first and let the rocks tumble from 7-10 days (for optimal polishing). You will do this for each grit you use.
Make sure there is no grit transferred from one step to the next. Hope this helps :)
Edu-Science Toys | Answered on Dec 28, 2010
Disconnect the electrical connector that joins the arches. Unscrew the half of the arch that holds the batteries. Check the red lead from the battery compartment. Mine had two problems - it was almost disconnected from the battery, and had another disconnect in the middle. Twist the wires together at both fault points and tape (electrical tape) or solder. I soldered and my Learning Home is now working perfectly.
--gdipersio
Toys | Answered on Nov 16, 2020
There are tutorials and video's on YouTube and on Goggle then on how to make your own decorations for birthdays and for Christmas and Easter and Halloween and for Valentines day too.
Toys | Answered on Nov 11, 2020
Put the crank handle in the down position and then use the arrows on the gears to guide you. The two gears that hold the two spirals should be closest to you. Make the two arrows on the gears point directly at each other(keeping the crank in the down position). The third gear's arrow (furthest from you) should point directly at you bisecting an imaginary line formed by the other two arrows pointing at each other. The idea is to get the spirals lined up so they create a channel for a ball to fit in.
Toys | Answered on Oct 04, 2020
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Toys | Answered on Sep 29, 2020
Maybe you can search on Amazon or Ebay. This manual is cetainly on sale.
Toys | Answered on Aug 28, 2020
Edu-Science Edu Science Microscope 600X Logo
11 questions posted
Top Edu-Science Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you an Edu-Science Toy Expert? Answer questions, earn points and help others
View Most Popular
Edu-Science Toys
  • Edu-Science Toys
Most Popular Question
edu science 600x microscope no
  • Toys
