20 Most Recent Westpoint TV-201 Microwave Oven Questions & Answers
I have a WCC6640GGLI cooking
Should be about 365 degrees Fahrenheit; if that helps. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
6/4/2016 4:26:27 PM • Westpoint TV-201... • Answered on Jun 04, 2016
3answers
A WESTPOINT WQP12-9011E DISHWASHER, USER MANUAL
Try:
https://www.2instructions.com/results_mm.php?marque=WESTPOINT&materiel=Dishwasher
9/11/2013 6:02:55 AM • Westpoint TV-201... • Answered on Sep 11, 2013
3answers
OSTER MICROWAVE 1.1 MOD OGF41101-RUNS BUT WON'T HEAT.
There are two fuses in a microwave oven, and for the non-heating problem the problem is the high voltage fuse, incapsulated between the transfo and the magnetron. This supports up to 5000V and usually rated something like 0.65A/0.7A/0.8A and even 1A.When you open the capsule, you'll see it sitting there between its two connectors, and you'll notice the filament inside the glace is broken. Buy a new one and your machine will work like a horse.NOTE: Try to get the same ratings fuse, or else the oven will smoke and smoke the house with it, so be careful.The other fuse is smaller, and usually ceramic one, which can be found on the PCB, if that goes, you should get no power at all to the machine. If not sure, let a professional do the job, it's safer.
4/7/2013 1:12:17 AM • Westpoint TV-201... • Answered on Apr 07, 2013
My microwave comes on but want heat up the food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
9/9/2011 2:45:24 PM • Westpoint TV-201... • Answered on Sep 09, 2011
My microwave oven works but
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
2/19/2011 11:04:11 PM • Westpoint TV-201... • Answered on Feb 19, 2011
I have a 220 Advantium.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
9/1/2010 3:34:14 AM • Westpoint TV-201... • Answered on Sep 01, 2010
If I use a finish
If i may i understand the question very well, you can put the tablet in midst of the the washing of the dish or perhaps you can dissolve the tablet and pour the dissolved tablet on the dish, it will circulate round while the dish is been washed.
Take care.
5/25/2010 1:05:54 PM • Westpoint TV-201... • Answered on May 25, 2010
Hi There my dishwasher WESTPOINT
Hi
Thanks for using FixYa. Check the water temperature inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
5/17/2010 4:12:58 PM • Westpoint TV-201... • Answered on May 17, 2010
Can you use a microwave if the glass on the door
It is not advisable. The door is a critical safety part of the microwave oven. The glass being gone will allow heat in areas of the door not designed for heat. The glass also is a support for the safety mesh that contains the microwave energy to the cavity.
5/12/2010 7:22:43 PM • Westpoint TV-201... • Answered on May 12, 2010
My microwave has a hole burned through the door.
This can start when food splatters on the inner door, then from that point the microwaves that do the cooking are attacking that splatter eventually burning a hole in the door. Do not use the microwave oven in this condition. You will need to have the door parts that are damaged replaced
5/8/2010 9:07:18 PM • Westpoint TV-201... • Answered on May 08, 2010
The plate inside the microwave is not rotating
puk code for +918095649347
4/12/2010 6:00:54 AM • Westpoint TV-201... • Answered on Apr 12, 2010
No metal is in microwave but it light flashes
Are you certain there is no metal or metal containing racks or dishes?
BTW, wire racks (round wire) are ok because the microwaves travel around the round wire. Flat metal reflects and causes arcing.
Thanks for your question at FixYa.com
2/16/2010 3:33:33 PM • Westpoint TV-201... • Answered on Feb 16, 2010
I accidentaly torn the waveguard cover for my new
The waveguide cover will need to be replaced.
It provides critical protection for the magnetron.
You can contact Oster at the number in your owner's manual to see where you can order a new one.
If for some reason you do not have your manual, try 1-866-866-6283.
1/31/2010 4:13:18 PM • Westpoint TV-201... • Answered on Jan 31, 2010
Microwave Ovens Logo
43 questions posted
Top Westpoint Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
Aron
Tom Chichester
Are you a Westpoint Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Westpoint Microwave Ovens
Most Popular Question
accidentaly torn waveguard cover new
  • Microwave Ovens
