20 Most Recent Garmin Nuvi 1450LMT Questions & Answers
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Garmin Nuvi... | Answered on Jan 07, 2018
connect your gps to computer and look at the files in the poi folder. they should be gpx files. When poi loader does its thing it converts the csv files to gpx maybe something didn't work the last time you loaded files.
Garmin Nuvi... | Answered on Nov 17, 2017
How did you charge it? If you did not use a high power USB charger, try that overnight. A USB charger provides a lot more powr than your PC. Leave it plugged in and off overnight.
If that does not work, Amazon sells battery replacement kits.
Garmin Nuvi... | Answered on Apr 12, 2017
Check USB power cable it could be bad. If you have a micro USB connect to computer. If it gets power then you charger is bad.
Garmin Nuvi... | Answered on Mar 07, 2015
Try a new USB port or cable... Its simple but it works. If not try on another PC. If it works . if not your GPS has a USB problem
Garmin Nuvi... | Answered on Nov 09, 2014
Unfortunately, this is the result of a defective LCD display. A transistor in the LCD matix is either stuck on or off, causing the line. The display must be replaced. More info on this can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Garmin Nuvi... | Answered on Nov 03, 2014
What do you mean by "press dot"? Please give more details.
Garmin Nuvi... | Answered on Oct 15, 2014
Sorry to say but this is a result of a failed firmware or map upgrade. Sometimes a break in the data communication between your GPS and PC can cause a failed upgrade. When you turn on the unit and it just displays the Garmin logo, sometimes in an endless loop, this is a boot problem. The unit can not find the proper files or they are corrupted. More information can be found here: SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Garmin Nuvi... | Answered on Sep 16, 2014
Is the map turned on? At the main menu, press the system tools icon and press the map icon. Then press the map info button.
What does it say? Does a map show up and is there a checkmark in the box next to the map description? Also, if the map is for a certain area, say lower 49 states, SW, well you won't be able to find a city in the NE because the map is only showing a limited area. If you have ample memory on the unit or have a 2GB or larger SD card, installing the full US & Canada map is the way to go. Make sure the map installed on the unit covers where you are and where you may be going.
Garmin Nuvi... | Answered on Sep 04, 2014
Press and hold power and upper left corner on screen,then connect with usb cable with pc.
Garmin Nuvi... | Answered on Jul 29, 2014
Try calibrating it first. If that doesn't work, then it needs to be replaced. If it is cracked in any way, it needs to be replaced.
The calibration procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Garmin Nuvi... | Answered on Aug 29, 2013
Has your PC ever been able to recognize the Nuvi? A common problem on the Nuvi 11xx, 12xx, 13xx & 14xx are broken connections between the rear USB port and the printed circuit board. This will prevent communication between a PC and the Nuvi. It can also affect charging.
Have you tried the unit on a different PC or operating system?
Garmin Nuvi... | Answered on Mar 18, 2013
Press "where to", Press "favorites", Press "all favorites", his will list all favorite points stored in the unit. Scroll down til you find the point you want to edit. select it. It will show up on the map, and in the info bubble, it will say in blue "click for more", touch the blue words, and it will take you to a screen where you can select edit or delete.
Garmin Nuvi... | Answered on Jan 21, 2013
usually in the garmin charger its in the end unscrew it ~(be careful theres a spring in there thats mega important!) in the car socket its a 7.5A fuse. but it in the garmin its the same possibly a 10A fuse, but these are of a tube type not a blade!
Garmin Nuvi... | Answered on Oct 06, 2012
Have you tried installing and running the Garmin Lifetime Updater?
Link to download here:
http://www8.garmin.com/support/lifetime_updater.html
After installation, you will need to connect your device via your USB cable to your computer.
Garmin Nuvi... | Answered on Sep 05, 2012
Garmin Nuvi 1450LMT Logo
47 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
Garmin GPS
  • Garmin GPS
Most Popular Question
custom poi doesn 39 t go
  • GPS
