20 Most Recent Tascam HHB DA30 Tape for DA-88 Questions & Answers
Well, i guess the experts are all asleep on this
well i am far from an expert but dont like to see you unanswered try this web page for the da-88 specifically http://mixonline.com/mag/audio_da_maintenance_upgrades/
hope it works for you
6/3/2010 12:17:00 AM • Tascam HHB DA30... • Answered on Jun 03, 2010
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
6/1/2010 12:45:41 AM • Tascam HHB DA30... • Answered on Jun 01, 2010
The red error light keeps coming on, with
The cleaner tape is only supposed to be used after 50 hrs of record /play time , if you are using your cleaner tape alot , you are damaging the helical scanning head and wearing out it,s sensitivity ,
Users have found out that the cleaning tape is like sandpaper made to remove metal particles left behind everytime you run your high 8 tapes , The best way is to send it in to a authorized tascan repair shop in your area , don,t worry there,s always some shops that can be found in your area , they will do a bench test for around 45-50 bucks and tell you what if anything it will cost to fix your problem ! if it turns out to be a dirty helical scanning head they will clen that with 100% alcohol and test it , that they can do usually for the price of the bench test since they do have to remove the cover to see whats going on under the hood! , well the red error light on my machine does come on sometimes when my 2 machines are out of sync, but with shutting the unit down and starting it back up usually takes care of that issue...by the way how often do you use the cleaner?..most da-88 users are totally affraid of even using them !, good luck and if you have any more questions please feel free to email me> glenn
5/31/2010 10:08:50 PM • Tascam HHB DA30... • Answered on May 31, 2010
0answers
0answers
0answers
0answers
Using the advanced song management feature on my
First, try formatting the Partition 03. Press MENU and select the DISK menu. Select the REFORM action and press the arrow key that points to the Right. Select the partition to be re-formatted (shown by the cursor) and press ENTER. Press ENTER to reformat the partition.
If this doesn't fix the Error message, you will need to contact Tascam Support for futher help: http://tascam.com/support/
Here is an electronic copy of your Manual: http://tascam.com/content/downloads/products/350/dp01fxcd_eng.pdf I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2/28/2011 1:53:35 AM • Tascam... • Answered on Feb 28, 2011
Which tascam us-122 driver works for windows 7
Officially there are no specific drivers for US-122 for windows 7. In case you have an error I suggest you to download the winXP v.3.40 from this link, unzip the files from the downloaded one, right click on the file US122_Win_3.40f.exe, choose properties, go at the compatibility tab and check compatibility with Windows XP sp3 and click apply - ok. After this install the drivers with double click on this file and check the results.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
12/26/2010 5:43:27 PM • Tascam... • Answered on Dec 26, 2010
0answers
Want to copy files from Tascam 788 to IMAC's Garage Band
The problem is thus. You have a multitrack recording saved in a format that your portastudio recognizes and you want to use it on your imac. If you can copy the file to the imac as a file, a translator, if one is available, will make it usable by the mac. You won't be able to play it and record on the imac because maintaining the recording as multitrack would require one output from the portastudio and one input on the imac for each recorded track.
Bummer dude. The kluge method would be to play/record 2 tracks at a time (or however many outputs and inputs are available) and hope for some semblance of time alignment, after which you can fine tune it and then start your editing.
5/19/2009 4:10:38 PM • Tascam... • Answered on May 19, 2009
Electronics - Others Logo
4 questions posted
Top Tascam Electronics - Others Experts
Ekse
Tom Chichester
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Tascam Electronics - Others
Most Popular Question
guess experts all asleep
  • Electronics - Others
