20 Most Recent Tascam CDa500 CD/Cassette Combination Player System Questions & Answers
Mech cannot be replaced, but can be fixed. Almost all individual parts are still available from Teac.
Tascam CDa500... | Answered on Feb 16, 2010
You control the volume by the amplifier or receiver that you plugged the tascam into. The only volume control on the tascam appears to be for headphones, the other volume control is for recording gain input.
Tascam CDa500... | Answered on Jan 31, 2009
What is your question, please?
Comment menu can be used to add information to your question.
Free online manual at the internet link below:
https://tascam.com/downloads/tascam/342/CC-222MK3_manual.pdf
Tascam Audio... | Answered on Jul 06, 2020
https://www.youtube.com/watch?v=yaVE-39gS4g
https://www.scribd.com/doc/229500599/Tascam-DM-3200-Service-Manual
Tascam Audio... | Answered on Apr 16, 2020
I don't see any mention of an "Auto repair program" in the manual.
Tascam Audio... | Answered on Sep 27, 2019
Hello Henry, I sent you the link to download the user manual of your Tascam DP2 and see there, what are you looking for
I hope you can solve your need
Greetings Franco Dosil
Hola Henry , te envio el link para que descargues el manual de usuario de tu Tascam DP2 y veas ahi, lo que estas buscando
Espero puedas resolver tu necesidad
Saludos Franco Dosil
https://tascam.com/downloads/tascam/37/E_DP-02&02CF_web.pdf
Tascam Audio... | Answered on May 17, 2019
Hello Donnie, I sent you the link to download the user manual of your Tascam DP2 and see there, what are you looking for
Hola Donnie, te env?o el link para que descargues el manual de usuario de tu Tascam DP2 y veas ah?, lo que estas buscando
Hello Rick, to be able to activate the recording button, you must have placed a cassette, that has the lock to record, this is in the upper part of the cassette and has one for each side, in your case it will have to have the corresponding to the on the side that you use to record
Looking at the cassette in front, with the tape down, the lock is up on the left, if you do not have it, you can replace it with a Scotch tape covering the hole
I hope my comment will serve you
Hola Rick, para poder accionar el boton de grabacion, debes tener colocado un cassette, que tenga la traba para grabar, esta se encuentra en la parte superior del cassette y tiene una para cada lado, en tu caso tendra que tener la correspondiente a la del lado que usas para grabar
mirando el cassette de frente, con la cinta para abajo la traba esta arriba a la izquierda, si no la tuviera, la puedes reemplazar con una cinta Scotch cubriendo el agujero
Espero que te sirva mi comentario
https://upload.wikimedia.org/wikipedia/commons/thumb/0/05/Cassette_Write_Protect_IV.jpg/220px-Cassette_Write_Protect_IV.jpg
Tascam Audio... | Answered on May 08, 2019
Hello Ken, I was looking in the manuals of Tascam 302 and it does not refer to "ERR 1", it appears "ERR 2" and "ERR 3"
From what you describe, you may have a power supply problem in the low signal area, or have some of the mechanisms out of point, so you can see that the axes are turning
If you have technical features, try disconnecting the multipin cable that feeds the mechanics and check if the noise continues, if it does not appear, go reconnecting each mechanism separately and looking for which generates the problem, could be both, at that point I suggest, consult to a specialized technical service
I hope my comment has served you
Hola Ken, estuve buscando en los manuales de Tascam 302 y no hace referencia a "ERR 1", aparece "ERR 2" y "ERR 3"
Por lo que describes puede ser que tengas un problema de fuente de alimentaci?n de la zona de baja se?al, o tengas alguno de los mecanismos fuera de punto, por eso observas que est?n girando los ejes capstan
Si tienes conocimientos t?cnicos, prueba desconectando el cable multipin que alimenta las mec?nicas y verifica si continua el ruido, si no aparece , ve re conectando cada mecanismo por separado y buscando cual genera el problema, podr?an ser los dos, en ese punto te sugiero, consulta a un servicio t?cnico especializado
Espero te haya servido mi comentario
Tascam Audio... | Answered on Apr 24, 2019
Tascam CDa500 CD/Cassette Combination Player System Logo
4 questions posted
Top Tascam Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tascam Audio Players & Recorders
Most Popular Question
cd portion tascam cda500 replaced
  • Audio Players & Recorders
